I built another RS61 for this proxy. This one was meant to run a little quicker then the first one. The body is a resin cast from a master I carved out of wood.
It is powered by an Avant green long can 180( 19700 rpm @ 12 volts). I utilized an Avant inline pod, brass plate and some Lego front bearing blocks. Rear axle runs in bearings and the front axle uses nylon bushings.
CB wheels with PGT urethanes
Home cast resin wheel inserts
Pioneer guide
Tired of silver I decided to paint this one red, with minimal decaling. I may add a tire and petroleum sponsor decals as well
