Matt, these bodies are multiple pieces. when epoxied together, they become stronger than a single piece unit. The floor pan is thick enough to hold body screws very well also. I put a hundred laps on this one today for fun. I am going to build a brass chassis for the next one with more suspension detail. the rear wing on this is thin brass sheet bent to the same shape as the speedway wing in the kit. It should hold up pretty well.
Im sure the mirrors will get lost soon, but for now, it looks pretty good and runs fantastic! those big meats on the back are urethanes and they really bite. I used a piranha in this one cause that's what I had on hand.
I think one could add, or eliminate as much detail as they wanted on these, depending on how they would be raced. I need to spend more time on the rear end area, but it is not really needed to race them.
