Revo Slot 1/32 Porsche 911 GT2 -Please Help!- =Solved!=
Postby ePilot » Mon Nov 06, 2017 4:14 pm
Hi everybody,
Does anyone know how to de-mount the flag holder (appropriate term?) without destroying it?
That red thing...
Regards Gerrit
ePilot
Re: Revo Slot 1/32 Porsche 911 GT2 -Please Help!-
Postby MrAdept » Mon Nov 06, 2017 4:25 pm
From the images I have seen on 132slotcar and Pendleslotracing it looks like the guide holder is 2 pieces
https://www.pendleslotracing.co.uk/medi ... /rs106.jpg
Not sure if that gets you any further though!
Mark
MrAdept
Postby ePilot » Mon Nov 06, 2017 4:57 pm
Thanks Mark,
I know it's two-piece, but not that there's no thread on it!
Probably the RS people used Loctite so I think the burner needs to be hotter the second time! I this tried before with no result...
Gerrit
ePilot
Postby MrAdept » Mon Nov 06, 2017 5:58 pm
It may be an interference fit, saving on glue...
You may need a pin punch to drive the 2 pieces apart.
Mark
MrAdept
Re: Revo Slot 1/32 Porsche 911 GT2 -Please Help!- =Solved!=
Postby ePilot » Tue Nov 07, 2017 10:47 am
Hi Mark,
Problem solved!
Exactly as you told.
I made an improvised tool. A 7.1mm hole in a piece of 12mm brass and a 3.95mm brass driver.
And a little blow with a small hammer...
Gerrit
Image Image Image
ePilot
Postby nhdungeonracer » Tue Nov 07, 2017 11:31 am
Curiosity has the best of me and I have to ask, why did you need to remove the guide post holder?
Do you have a better idea or solution than what was there?
Re: Revo Slot 1/32 Porsche 911 GT2 -Please Help!- =Solved=
Postby MrAdept » Tue Nov 07, 2017 12:16 pm
Very nice!
Mark
MrAdept
Postby ePilot » Tue Nov 07, 2017 3:33 pm
Thanks Mark!
@nhdungeonracer:
If I get a new type of car then I always disassemble it till latest bolt...
and that includes the guide post holder too...
Thats my kind of curiosity...
In the subsequent assembly session I always try to improve something. Yes, sometime it fails...
I am also investigating the possibilities of using a pipguide (slideguide) by PipSlot in this model
Here you will find the history of the development of the Pipguide by PipSlot:
viewtopic.php?f=5&t=15836&hilit=pipguide
Gerrit
ePilot
Postby nhdungeonracer » Tue Nov 07, 2017 8:36 pm
Ah, I get that...
They say curiosity kills the cat, but sometimes that's how you learn things too...
Carry on, my friend! :D
Postby busterfla » Fri Dec 22, 2017 12:54 pm
Did anyone find a 3/32 bearing that would work for the Revo Slot chassis?
Buster
busterfla
Postby ePilot » Sat Dec 23, 2017 5:03 pm
Hi Buster,
You could use the Scaleauto SC-1329 flanged ball bearings 3/32 x 6mm. However not very cheap!
Beware if you order them then it is possible that these bearings are wrongly packaged with a wrong number (SC-1324). Like mine!
There are other sources too.
In the left you see the 3/32" bearing:
Here I have them applied too. With the usual NSR, Slot.it etcetera stuff.:
Gerrit
ePilot
Postby busterfla » Sun Dec 24, 2017 10:02 pm
Thanks for the info, will hunt them down after Christmas
Buster
busterfla
Users browsing this forum: Google [Bot] and 3 guests
