If you feel that the motor in your car is not powerful enough how do you pick something better? There are dozens of motors of each type to choose from. There is more info on how measurements can be done here:
http://slotcarnews.blogspot.com/2007/02 ... -list.htmlThis is the formula for calculating watts: ((Max RPM/2)*(max torque/2))/100,000 = Watts , the torque would be in gram centimeters.
If there are watt ratings available for a motor that you are interested in that would be helpful.
In the past I was involved in doing some motor testing, I was given two sets of motors, each set was made to the same specifications. I broke the motors in on the bench and measured the RPMs at 12 volts. I then put each motor in a car and ran it on the track. The car did not have traction magnets and I ran it at both 10 and 12 volts. I made note of the best lap times, how easy the car was to drive and anything else that stood out about each motor. After the track testing I measured the RPMs again.
One result of my testing was that RPMs alone would not tell you which motor would be best on the track. In one set the motor that gave the best lap times and driveability did not have the best RPMs. I was later informed that other people that had done similar testing had reached the same conclusion.
Having a more powerful motor is not always going to increase your chances of winning races. Before you switch motors you need to determine if lack of power is your real problem. Having a more powerful motor might get you a fast lap every now and again, but if the car is more difficult to drive your average lap times and number of offs might suffer.
