Home Racing World • View topic - Cheetah Redux
Cheetah Redux
Cheetah Redux
Postby Quickcars » Sun Jul 08, 2018 4:15 pm
I decided that my little orange Strombecker Cheetah needed an update. I wanted something different than what I've seen before and I wanted to just be able to use the parts in my existing bin to pull it off. It was already mounted to an HRS chassis. I used a set of Sideways BBS rims and some random decals. It still needs a bit of work but I like the overall look of it.
Quickcars
Re: Cheetah Redux
Postby chappyman66 » Sun Jul 08, 2018 5:28 pm
Updated Strombecker for the win! Nicely done.
I will say it again.....decent bodies, close to scale, and can be made into beautiful cars with some work.
Re: Cheetah Redux
Postby waaytoomuchintothis » Sun Jul 08, 2018 7:44 pm
Yep. That's why I look for old Revell, Strombecker and a few others.
Paul's gorgeous Cheetah is exactly the kind of car I aim for when I pick these up. Nice job, Paul.
Re: Cheetah Redux
Postby vonsirius » Mon Jul 09, 2018 1:27 pm
lovely, good job!
vonsirius
Re: Cheetah Redux
Postby Quickcars » Mon Jul 09, 2018 2:46 pm
Thanks fellas! Thankfully it runs better than it looks. I'm already on the lookout for another one to customize.
QC
Quickcars
Re: Cheetah Redux
Postby Fathead59 » Thu Aug 09, 2018 5:57 pm
OK, I ask this in another part of the forum, just bought a monogram cobra that has a drive shaft, my questions are , is the drive shaft hard to work on and how well does it preform over all over the other types, as in side winders and piñon & crown gear types, so far first one that I have seen, been out of the loop of slot cars for a long time ( AFX ho size when I was younger , and that is enough info ) . It is a nice looking car but I might change the color of the car and maybe stripes and numbers when it comes down to it, as much info as I can get would be a big help. Thanks
Fathead59
Re: Cheetah Redux
Postby Fathead59 » Mon Sep 17, 2018 11:41 pm
Was able to get two more cars and they both have drive shafts, all I am looking for are the pros and cons with this type of car . Was planning on repainting the first one but now that I have a set of them I am going to leave them alone.
Fathead59
Re: Cheetah Redux
Postby waaytoomuchintothis » Tue Sep 18, 2018 10:44 am
Empty a ball point pen ink cylinder, wash it out with isopropyl, then cut a short piece to replace that PIA spring. I think SCC has a replacement tube, so you can short cut that process quick and easy. When you get comfortable with such things, there are ways to convert cars to sidewinder or anglewinder configs, and you may want to play with that concept, too.
Re: Cheetah Redux
Postby Fathead59 » Sat Sep 22, 2018 5:02 pm
So, you can use those types of springs . That is good to know, I just hope no one gets mad at me for taking them, even when they are not dead.
Fathead59
Re: Cheetah Redux
Postby slothead » Sat Sep 22, 2018 8:29 pm
If needed you can replace the spring that connects the motor shaft to the drive shaft using a piece if the ink tube from a ball point pen. But, the original springs are dependable - I've only had one out of 10 to 12 cars have the spring break in over 8 years. There should not be a lot of stress on the spring as long as the motor and drive shaft are properly aligned, and the motor isn't being stalled while sanding the rear tires.
If you want to be prepared, go ahead and order some replacement driveshaft springs from SCC.
slothead
The Doctor is IN!
Re: Cheetah Redux
Postby Fathead59 » Mon Sep 24, 2018 6:44 pm
Thanks for the reply guys, are the drive shaft cars better then the sidewinder or piñon drive cars
Fathead59
Re: Cheetah Redux
Postby Modlerbob » Mon Sep 24, 2018 7:26 pm
Better for what? I don't know anyone who thinks slot cars with front motors and a drive shaft to turn the rear axle have any advantage over the other options.
Re: Cheetah Redux
Postby Quickcars » Mon Sep 24, 2018 8:15 pm
How did this thread turn into a front motor discussion?
QC
Quickcars
Re: Cheetah Redux
Postby Fathead59 » Wed Sep 26, 2018 12:28 am
I was just asking questions about those types of cars because I have 5 of them now. Just trying to get as much info on them as I can
Fathead59
