One is for the fan that is just below the bed - debris can fall into here. So here's the fan guard: https://www.thingiverse.com/thing:2935204
The other is something that actually just ruined 10 figures that were half printed - literally. I checked the job and the nozzle was 1/4" above the print and no filament was coming out. The reason is that with the stock spool configuration, the filament can actually wear the hole it goes through as it goes into the extruder, causing an oblong opening. My filament jammed in the hole. To print this new part to guide the filament better, I used two zip ties to get it back to a location it can feed through without jamming again.
Here is the filament guide: https://www.thingiverse.com/thing:3059604
You'll also notice the tape - it isn't for adhesion - it is to make stuff easier to get off when done. I've gouged the plate pretty good when figs are a little too stuck on!
Hope that helps folks!
