Micro break?
Micro break?
Postby Slotcar13 » Mon Mar 25, 2013 9:01 am
Guys,
Can any one make me a mini break for bending brass? I need it to be bench mount able to bend brass sheet up to 1/16 thick. The size I'm looking for is 6-8" ya not big but need nice 90deg bend repetitly. I have a big bread that dose not cut it due to its to big and the hf one is still to big for my needs.
Paul
Slotcar13
Re: Micro break?
Postby RazorJon » Mon Mar 25, 2013 9:21 am
I want one 2
Re: Micro break?
Postby Jesla » Mon Mar 25, 2013 10:09 am
Yeah...me three....
Jesla
Re: Micro break?
Postby 4424ever » Mon Mar 25, 2013 10:27 am
Here in CANADA Princess Auto sells a small benchtop brake. If on sale you can grab it for about 20 bucks. Not sure if that helps but you can atleast check it out on the web!
4424ever
Re: Micro break?
Postby Czar » Mon Mar 25, 2013 10:51 am
Czar
Re: Micro break?
Postby ddyke » Mon Mar 25, 2013 11:32 am
I got one from Grizzly but then found the exact same one at MicroMark and Harbor Freight.
http://www.harborfreight.com/18-inch-be ... 39103.html
ddyke
Re: Micro break?
Postby RazorJon » Mon Mar 25, 2013 11:41 am
looks good but the specks are a bit shady
.02 X 3 hard brass is its max range
I build my bulkheads from .062 X .5 brass I wonder if it will bend that
anyone have one of these?
Re: Micro break?
Postby bill from nh » Mon Mar 25, 2013 1:07 pm
Jon, I have one of these that doesn't get much use. I do not think its strong enough to bend .062" stock.
bill from nh
Re: Micro break?
Postby Slotcar13 » Mon Mar 25, 2013 2:04 pm
Will it bend 1/16 thick or .046 brass? Looking to bend pans for mounting body's to.
Paul
Slotcar13
Re: Micro break?
Postby Slotcar13 » Mon Mar 25, 2013 2:06 pm
Correction .040 thick brass?
Paul
Slotcar13
Re: Micro break?
Postby ddyke » Tue Mar 26, 2013 4:56 am
The one I posted will not make that narrow of a bracket without making a narrower top plate for the brake.
ddyke
Return to SlotCar ToolTime
