Home Racing World • View topic - Mazda 787B´s chassis converted ...
Postby pfuetze » Thu Mar 28, 2013 3:08 pm
Finally finished the 787´s after having them stand around till christmas ...
They got type 3 chassis under them with silicone rings to dampen out possible vibrations. Works quite nice :D
Together with the 962´s they make good running mates :D
cheers,
Peter
Re: Mazda 787B´s chassis converted ...
Postby mgs75thmeu » Fri Mar 29, 2013 9:36 am
Nice!! I see you're using the DSlot screws to attach the chassis too...
mgs75thmeu
Postby Cjent » Fri Mar 29, 2013 11:35 am
Super cool, Peter! They sit lower with your chassis it appears.
Cjent
Postby BRS Hobbies » Fri Mar 29, 2013 11:37 am
Peter,
The cars look great! Can you use braid with your guide or is it possible to use the stock DSlot43 guide with your chassis?
Best regards,
Brian
BRS Hobbies
Re: AW: Mazda 787B´s chassis converted ...
Postby pfuetze » Fri Mar 29, 2013 12:23 pm
Brian, the original DSlot guide can be used, too, with one very minor modification. I think i posted a pic on the thread of the 962. Will look for it a little bit later ...
Postby ElSecundo » Fri Mar 29, 2013 1:08 pm
Looks fantastic!
If somebody said "Hey, check out my Slot.It picture" it would take a pretty keen eye to spot any difference. :)
ElSecundo
The Great One
Postby Tigeracer » Fri Mar 29, 2013 1:11 pm
They look awesome , Peter!
Tigeracer
Postby pfuetze » Fri Mar 29, 2013 3:03 pm
viewtopic.php?f=6&t=1550
Brian, if you follow the link, you can see pics where i used the Kyosho guide. only needed to trim the guide stops on the side ...
Chuck, yep, they sit lower, it was my attention to get them lower, too :D
Bill, the Dslot screws work great with the body holders that are coming with the chassis. But metric screws M2 work great, too, even without cutting a thread. With conical heads, body float adjustment is easier.
Postby Broman62 » Sat Mar 30, 2013 4:17 pm
