Home Racing World • View topic - Lead Wires
Lead Wires
Share Your Thoughts!
Lead Wires
Postby jmsh54 » Thu May 16, 2013 5:22 pm
Here is a ha
jmsh54
Re: Lead Wires
Postby Wolseley Hornet » Fri May 17, 2013 2:55 am
What a good idea.
Soldering those tiny motor tabs always gives me the willies (hope this doesn't translate into something rude in its Atlantic crossing!) - even worse is unsoldering and cleaning up!
David.
Wolseley Hornet
Re: Lead Wires
Postby HomeRacingWorld » Fri May 17, 2013 5:49 am
Good info sir, thanks for sharing it.
Re: Lead Wires
Postby Florida_Slotter » Fri May 17, 2013 8:48 am
Re: Lead Wires
Postby Abarth Mike » Fri May 17, 2013 11:39 pm
Damn,
I bought the wrong one :o :D
Abarth Mike
Re: Lead Wires
Postby masmojo » Fri Jun 14, 2013 11:15 am
Along these lines you can get a silicone jacketed wire that makes a nice motor lead in the R/C section of your hobby shop. Sometimes it hard to find one fine enough for slot cars, but when you do it's about 10 times that length for the same price & you have your choice of colors. Red, black, Blue, Etc.
The little Ferrules (or whatever you call them?)? Those can be found in the R/C airplane section sometimes; I am not sure quite what they use them for?? Lining the holes are linkages and wire's I think, but again 10 or 12 are usually a couple bucks.
While I am at it if you use allot of lead to weigh your cars, they have that in the airplane area as well and it's double the size of the other packs you might find in the hobby store (Example: pine wood derby section) for 1/2 the price!!
There hope that helps you slot on a budget!!! ;-)
masmojo
Re: Lead Wires
Postby noddaz » Fri Jun 28, 2013 7:28 pm
noddaz
Return to Product Reviews!
