by pfuetze » Fri Jul 19, 2013 9:32 am
maybe, when i find a little time, i could adept the kyosho chassis to fit the G9330, should not be a big job - BUT- which gears to use? Which axles and bearings?
Magnet or no magnet - i´m sure Bill will vote for magnet ...
Marc, very interesting chassis, but for that power of the G9330, i´m not too sure if the chassis is strong enough. Did you plan a magnet pocket? Without magnet, it could work. good to see you changed the metall pinion of the G9330 (also known as the crown eater) to a plastic one.
