Alfa romeo 33/2 1968 1000 km
1/24th Scale Slot Car Forum
"Home Of The Big Ones!"
Postby cbracing » Fri Oct 04, 2013 2:36 pm
I have started and like alfa sports cars from the years 1960-70. So a year ago I built a alfa romeo 33/3 who won at Watkins Glen in 1971. This time it was the desire of a new resin body from werks, and the choice fell on an Alfa Romeo 33/2 coupe that was running at the Nurburgring 1000km in 1968. The car's model is car # 16 and was driven by Nino Vaccarella
Sister car that was running in the same race.
Image resin body after the cutting, grinding, filling and bonding fotoetz
Primer and fabric colors painted, decals glued in place
Image 2 component clear coat is sprayed on the body
Window panes, rims, driver pack and some little things are glued into place in the body.
I think it will be a nice model this Alfa 33/2 coupe.
continuations follow
regards
Christer
cbracing
Re: Alfa romeo 33/2 1968 1000 km
Postby cbracing » Fri Oct 04, 2013 2:57 pm
Tonight I got on location dummy motor in the body. High intake funnels are neat ...
Christer
cbracing
Postby chris » Fri Oct 04, 2013 5:25 pm
One of my all time favourite Alfa's. You done good!
Really impressed how you have the glass such a nice flush fit.
Chris.
chris
Postby dreinecke » Fri Oct 04, 2013 10:13 pm
Absolutely gorgeous!!! Very nice work!
Postby dr fabio » Mon Oct 07, 2013 6:28 am
That is just super deluxe Christer!!!! Can you send me the link so I can have a look at the resin kit. A couple of questions. Across the centre line of the rear wheel arches what is the width of the model. And the same for the front wheel arches. Im looking to race something a little different as we have a 60s LeMans class. I want to know if the car is wide enough to suit the chassis we have to use. Also how on earth did you grind out the slots on the rear of the car??
Supurb!!
cheers
dr fabio
dr fabio
Postby cbracing » Sat Oct 12, 2013 2:43 am
33/2 is now finished :) , so tomorrow will be the test run. I'll measure the dimensions that are on the body so you get to know the wheelbase, width, front and back, waist width of the body is 58mm. I will return with the rest.
http://www.slotracingwerks.de
Christer
cbracing
Return to HRW 1/24 Scale
