had this one on the back burner for a while trying to find a tire solution. the "bicycle" tires that are on this thing were impossible for me to cast, too thin and stretchy. so, I had to break down and go the o-ring route. I will sand them a bit and hope they look better. the rims were a PITA, they are so thin I blew a couple of them out machining the insert recess, but I finally got a good set. chassis will be brass with no body posts. the axles run through the body sides and hold it all in place. gotta tone down that silver though. threw the last pic in there so you can see the difference in the broadspeed and Mercedes wheels
