Hi Everyone!!!!!!
Hi Everyone!!!!!!
Postby butterbean72 » Sun Nov 04, 2012 7:58 am
I am looking for Silicones that will work on a 1/32 Womp Car for my Home track we wanting to start Dirt Car class , if anyone knows where i can get please LMK. Butterbean
butterbean72
Re: Hi Everyone!!!!!!
Postby RichD » Sun Nov 04, 2012 8:33 am
Womp cars have 1/8th inch axles and the wheels and tires are really not 1/32nd scale. Your best bet is probably to coat the tires that came with the car with black silicone sealent. If you want to use regular 1/32nd silicone tires you will have to change to a 3/32nd rear axle assembly including the bearings, axle, crown gear and wheels.
Postby Kemtronracer » Sun Nov 04, 2012 8:43 am
Paul Gage sells urethane tires that work well on Womp hubs - that's what I use these days instead of silicon. I believe he's a sponser here so look on the HRW home page for the link. You can also coat your clean sponge tires with RTV silicon - it works best if you thin out the silicon with some mineral spirits.
Kemtronracer
Postby kevinjr » Sun Nov 04, 2012 8:50 am
pro track makes a set of silicones to fit womp axles at professor motor .910 diam
kevinjr
Postby hotrodlarry » Sun Nov 04, 2012 9:22 pm
Permatex " Windshield and Glass Sealer" It's silicone, but a lot thinner than RTV. Coat the tires, and let it set up.Works well on painted wood tracks, I'd imagine it would do the same on a plastic track
hotrodlarry
Postby butterbean72 » Mon Nov 05, 2012 7:47 am
I wan to say thanks for all the tip's and advice. Thanks again Butterbean
butterbean72
