artin 1:32 powerbases questions
Plastic Or Wood
All Things Track Building!
Postby demether » Tue Jul 08, 2014 3:54 pm
Hi,
I"m preparing my new track (waiting for delivery), and I'm wondering if artin powerbases (1/32) are molded with the included track, or attached to it with screws ? Any pics would be appreciated (2 and 4 lanes). I need this info to see how I'll build my layout table support.
thanks
demether
Re: artin 1:32 powerbases questions
Postby HomeRacingWorld » Tue Jul 08, 2014 5:37 pm
Thought I posted the Artin set reviews already, but here is the 4 lane power base.
But aren't you going to just hardwire the track instead of trying to use the power base? It's so much easier and more reliable.
Postby demether » Tue Jul 08, 2014 6:06 pm
thanks
You 're right I want to use the powerbases (the 4lanes for the oval, the 2 lanes for the inner road course) as extra track piece, not as powerbase. It's why I want to know if I can cut/remove the connectors box easily. My tracks will be wired to lab powersupply (8A) with XLR connectors, probably.
demether
Postby vins123 » Tue Jul 08, 2014 6:10 pm
Hi
If you use the power amp you talk in you another forum( ho routed...) 13v 8a , i guess Harry has the right answer, just connect you amp where is the best for you, and go to Artin review, you will find a lot of infos, that what i did when i construct mine a few years ago.
Sylvain
vins123
Postby HomeRacingWorld » Tue Jul 08, 2014 6:26 pm
My mistake, Yes, it's molded but the bottom is removed. You can slice it off with a Dremel though easily enough. Did that many times.
Postby demether » Wed Jul 09, 2014 5:45 am
I almost finished the layout for the inner road course. I just need to order a few more track pieces, but in Germany this time ;)
TOday I have some work on my house roof, so if I don't fall this afternoon, I should continue the preparation work tommorow.
demether
