Home Racing World • View topic - Question about the track in my new SCX GT set
Postby philo426 » Thu Oct 09, 2014 7:53 pm
The track is gray rubber like plastic that requires some sort of adapter to mate with black scx track.why the differing track types?Carrera does no such thing and I wonder if I made a mistake by going with the SCX set!
philo426
Re: Question about the track in my new SCX GT set
Postby vonsirius » Thu Oct 09, 2014 10:25 pm
The new scx track. it's a little wider than the black one. It is better if you race F1 or open wheel cars.
I have used the adaptation track and there's no problem, it works fine!
Anyway you can't use the old barriers and borders on the black track or vice versa.
vonsirius
Postby HomeRacingWorld » Thu Oct 09, 2014 10:43 pm
Well, I can't say it would have been my first choice. Hope you got a really good deal.
And I would not advise the older, black track. The slot is very shallow and most all the guides you have, especially your 1/24 and vintage guides will rub the bottom and snag on every joint. I doubt you want to start grinding all your guides.
I would start searching for sources of the newer track and stick with it, or start shopping for a new system.
Postby philo426 » Thu Oct 09, 2014 11:24 pm
Luckily i got a good deal but I don't think it is cool to not tell the consumer that the grey track is not compatible with the black track without the adapter despite the fact that they both share the SCX designation .seems a bit dishonest.The cars are very nice however!
philo426
Postby Nor Cal Mike » Sat Oct 11, 2014 9:23 am
Nor Cal Mike
Postby philo426 » Sat Oct 11, 2014 9:54 am
I did not know that!Thanks for the 411!
philo426
