Home Racing World • View topic - Somebody Call a Doctor.............
Postby Audi1 » Fri Aug 26, 2016 7:45 pm
'cause I'm actually thinking about starting up a "Cars that ran in the First Indy 500 Race" fun run.................. :o
Kind of a cool field of cars.
I'm taking two asprin now..................
Re: Somebody Call a Doctor.............
Postby HomeRacingWorld » Fri Aug 26, 2016 7:53 pm
"Waitress! I'll have what the gentleman on the floor is having..."
Postby ccobra » Fri Aug 26, 2016 8:18 pm
Complete with the smoke from those Cummins engines. :banana-dance:
ccobra
Postby Retro Racer 44 » Sat Aug 27, 2016 12:30 am
That sounds interesting, but the race would have all Wasps, as I doubt any other cars are available, bodies, or enough details to scratch build it.
Why not expand the theme to any car from the beginning to 1940 or something like that. There might be more choices.
Keith
Retro Racer 44
Postby waaytoomuchintothis » Sat Aug 27, 2016 10:48 am
I don't know... The cars looked very similar in those days when the first one was run. You might be able to form a base unit of body parts, and rearrange as required. The wheels are going to be the tough part. Maybe a resin casting to fit the Pendleslot PPVR01 23" wheels for wood spokes, and mix in a few that have wire wheels using the Pendle PP-PEW03. Pendle makes a nice tire for these wheels, too.
Postby waaytoomuchintothis » Sat Aug 27, 2016 11:27 am
There would be 40 cars, and aside from the Wasp (supposed to be the first rear view mirror, but it wasn't), the rest could be modelled using Miller front caps, and a variety of flat radiator grills. Most had a simple round tank mounted high at the rear, which gives you room to stuff chassis in underneath. Its 40 cars, but it could be done. You might be able to design a common chassis, that would ease things a lot..
Postby Audi1 » Sat Aug 27, 2016 12:17 pm
Believe it or not, me, of all people, was thinking about it as a scratch-builders proxy. Chassis, body, the whole thing. Good ideas about the shared parts, though. There were some very cool cars back in the day. Check out the bottom of this link for a list of the cars that ran in the first race in 1911.
https://en.wikipedia.org/wiki/1911_Indianapolis_500
Postby Retro Racer 44 » Sat Aug 27, 2016 1:12 pm
I hope my wife won't mind if I steal the toothpicks from the kitchen and start constructing wooden wheels. :lol: :lol: :lol:
A thin insert wheel with a purpose-cast "wooden spoke" insert might work.
I think it could be done, though how many years it might take to get a field of these things might be a problem. We aren't getting any younger, eh?
I wonder if there are 3D print files out there for any of these cars, or blueprint style drawings that could be used. Probably just for the Wasp.
Time to do some internet research.
Cheers,
Keith
Retro Racer 44
Postby waaytoomuchintothis » Sat Aug 27, 2016 1:48 pm
Postby TuscoTodd » Sun Aug 28, 2016 7:26 am
Postby Audi1 » Sun Aug 28, 2016 8:59 am
Postby TuscoTodd » Sun Aug 28, 2016 10:40 am
Hmmmm.... Wonder if a ff-030 is short enough to do as a side winder....
:think:
(yes - I think I am going to be a glutton for punishment and try to make one of these as well - FF-030 motor on order...)
:violence-stickwhack:
Now where to come up with large double flange wheels....
Postby Audi1 » Sun Aug 28, 2016 12:39 pm
I know a 3DP wizard named "Matt".......................maybe changing gearz would be interested in taking a look at this wheel issue................. if there's enough interest, of course..........
Postby Retro Racer 44 » Sun Aug 28, 2016 3:35 pm
The 3D wooden spoked wheels would be the ticket, but they would have to be done in a plastic that was not brittle, formed of durable plastic with hubs that could be pressed and glued. The rest of the car could easily be scratch built. O rings would make good tires. They could be ground flat and then recast to make urethanes. A garden hose O ring might be just the right size.
Since the motor would probably have to hang under the chassis for gear alignment, the hood and seats and back deck could probably be made out of styrene or even balsa wood. The frame could be built with rectangular brass tubing.
It is good to see some pics being posted. Keep them coming. Straight on side views would be helpful as well.
I love a challenge, let's make it happen.
Keith
Retro Racer 44
Postby waaytoomuchintothis » Sun Aug 28, 2016 4:07 pm
This just in...
Do you have old 1/32nd Highway Pioneers models laying around in the parts bin? The wheels will sand down to an exact fit in the big, thin Pendles wheels. The set I'm using is from a 1910 Cadillac. Good place to scavenge body parts, too.
Electronics Goldmine and All Electronics have lots of robot motors that come in all sizes. I'm even thinking about a chain drive!
