Lotus Europa build 3
Postby VTECFOUR » Sun Aug 16, 2015 8:34 pm
Finally starting a build using Devised Design products including the FF050 motor narrow chassis, front axle/guide mini carrier and guide.
Got an idea of incorporating a floating chassis pan.
Curious on how it'll compare to my other small car chassis builds with BWA and Winpod motor brackets.
VTECFOUR
Re: Lotus Europa build 3
Postby Alaskaracer » Sun Aug 16, 2015 9:42 pm
Looks good!
Alaskaracer
Postby chappy » Sun Aug 16, 2015 9:46 pm
I'll be keeping an eye on this one Dan.
I have the same parts including your body lol.
You are my Guinea Pig on this one lol
Postby VTECFOUR » Tue Aug 18, 2015 12:13 pm
Some progress on the chassis.
Made a perimeter pan of 3/32" square tubing and .016 and .032 strips. Held to the motor pod with four 2mm screws after tapping.
Screw holes in motor pod were slightly enlargened allowing some pan float. Oval hole in pan at back allows pod to be held to body independent of pan.
Will add some side brass pans for some tuning weight later.
Axle/guide carrier is hooked into motor pod with 3/32" piano wire allowing wheelbase changes. I like this feature.
So far so good.
VTECFOUR
Postby Z-carfan » Tue Aug 18, 2015 12:59 pm
Chassis looks sharp! I have that front guide, needed an example how to use and this is a very nice example. Thanks for sharing.
Postby VTECFOUR » Tue Aug 18, 2015 7:46 pm
Wheel arches trimmed and body mock fitted.
Ran out of Ranch Design rims, so a Slot It Ferrari 312 wheel set's being used.
Body mounting's next.
VTECFOUR
Postby Lou E » Tue Aug 18, 2015 7:52 pm
Looks good with the gold Slot.it wheels, do you plan on keeping them?
Lou E
Postby VTECFOUR » Wed Aug 19, 2015 2:51 pm
Made some chassis changes.
Cannabalized a previous build for the Ranch Design rims. The Europa body has enough front overhang to allow the use of Devised Designs longer front axle/guide carrier so it was substituted. Went for a Scale Auto universal guide with a thinner horizontal plane so the wheel/tires are closer to the track.
Getting there.
VTECFOUR
Postby VTECFOUR » Wed Aug 19, 2015 7:54 pm
Chassis's running. Powered by Scalextric red 20K FF050 motor. Geared with Scalextric Sport 9t pinion and SCX Pro 27t crown. Added .032 x 1/2" sidepans.
Runs smooth and has a planted feel. Hoping it`s as good after mounting the body.
VTECFOUR
Postby dreinecke » Wed Aug 19, 2015 7:57 pm
Looks like a great build going on Dan!
Postby VTECFOUR » Fri Aug 28, 2015 11:07 am
Windows cut and filed out. Body's mounted with the desired stance.
The Devised Designs extended axle/guide holder let me maximize the guide to rear axle distance. Handles just as well as my build 2 and is planted through the corners.
Quite pleased with the performance as I can keep up with stock Slot It cars.
Primer's next and then a traditional Lotus finish, green with yellow stripes.
VTECFOUR
Postby VTECFOUR » Tue Sep 15, 2015 12:18 pm
Some progress. Body sprayed with Tamiya fine grey primer and then TS43 Racing Green. Rims, bumpers, window trim and gas cap accented with Tamiya Light Gray bottle paint. Striped with Pactra trim tape.
Window installation and interior tray to come.
Runs well with good straight line speed and confident cornering.
I like the Devised Designs motor and front axle/guide brackets for small car builds.
VTECFOUR
Postby Audi1 » Tue Sep 15, 2015 7:53 pm
Looks very, very good! :text-bravo:
Postby TuscoTodd » Tue Sep 15, 2015 8:53 pm
WOW!
VERY clean looking build!!!
Thank you for sharing the pictures!
Postby dreinecke » Tue Sep 15, 2015 9:19 pm
That looks fantastic! I love the colors and you did a great job on the stripes! That chassis though...wow! Nice work!
