Home Racing World • View topic - HRW Autograss Mini Proxy
Re: HRW Autograss Mini Proxy
Postby HomeRacingWorld » Thu Nov 14, 2013 8:41 am
Those look perfect.
Postby hoganracing » Sat Nov 16, 2013 4:38 pm
hoganracing
Frequent Flyer
Postby Austin » Sat Nov 16, 2013 5:28 pm
Looks like I will add my roof fin and mail it off.
Patrick yours is looking good.
WH04, nice looking cars and truck
Austin
Postby HomeRacingWorld » Sun Nov 17, 2013 8:39 pm
Getting there.
Need the numbers and a couple other decals.
Body mounts are finished. Just need the new tires and it will be on the way.
Postby ListerStormGT » Mon Nov 18, 2013 2:59 pm
Everyone's cars are looking great! Hmm, strange you decided to use black and gold Boss... :lol:
I'm still working on a roll bar for mine then just need to mount the body and its done.
Postby HomeRacingWorld » Mon Nov 18, 2013 3:24 pm
Tire issues solved here. You should be able to smell the urethane as I have been grinding.
First test run is very good. I will be the slowest as usual...but fun to drive.
Postby waaytoomuchintothis » Mon Nov 18, 2013 4:42 pm
Postby HomeRacingWorld » Mon Nov 18, 2013 6:04 pm
What a hoot. Those are waytoowild :)
Postby TuscoTodd » Mon Nov 18, 2013 6:30 pm
That front drive set up is crazy! Love the variety of designs everyone has come up with!
Postby Austin » Mon Nov 18, 2013 6:58 pm
Nice chassis work, front wheel drive, Never tried anything like that but looks good.
Austin
Postby Wolseley Hornet » Tue Nov 19, 2013 3:20 am
Much better job than Scalextric made of it.
Where's the guide going to be?
David.
Wolseley Hornet
Postby waaytoomuchintothis » Tue Nov 19, 2013 9:37 am
It will hang from a plate that is mounted at the ends of those square frame rail tips you see. They will be ground down to a level angle for the plate
The other chassis will be mounted on a fiberglass plate which will be weight biased to the right.
With a little luck, they will be fairly heavy down low on the right side, with lots of grip, but able to slip on the left for turns.
I hope there's time for some really crazy paint. Some of those in the videos have been great.
Postby HomeRacingWorld » Thu Nov 21, 2013 8:39 pm
Looks good!
Postby Austin » Thu Nov 21, 2013 8:56 pm
Some day I have to put that number on the roof so I can send mine in .
Austin
Postby hoganracing » Thu Nov 21, 2013 9:32 pm
hoganracing
Frequent Flyer
