Well.... I DEFINITELY got behind on my build!
BUT! Today I am back to making progress!
The idea of using the Carrera Go wheels and tires, while "free" as I had them here - turned the project on it's head as I ran into issues trying to get a chassis built around press on wheels without having clip in bushings, while still being able to adjust gear lash (I didn't have any slot-it type gears around - only standard "non-capturing" type...
Soooo - chassis attempt #1 was finally scrapped today as I decided to go with set screw wheels...
Which led to the next issue - at this late hour - I didn't have time to order wheels / tires! So after a lunch break, it was back to the drawing board and the "spares" pile!
I have to say, what came out of it looks to have promise! It is going to allow me to use the Carrera Go! tires and wheels up front and tires with the wheels turned down on my dremel (have to get a mini lathe one of these days!) as inserts in the rear. The rear wheels are from some worn out JK8721P large hub tires that I removed around 3/16" of width from. All in all, I am pretty happy with how they turned out as it will still allow the car to have the "scale" size tires - but will fix my issue with not being able to come up with a good robust rear axle set up. :)
I snapped a progress shot and then a shot of what the finished product looks like...
Now I can get back to chassis design!
Enjoy!
:D
