Home Racing World • View topic - CanAm - Build Thread
Re: CanAm - Build Thread
Postby Racie35 » Sun Dec 06, 2015 7:24 am
Did you ever weigh what you ended up with from the Fly body vs the Carrera?
Racie35
Postby Audi1 » Sun Dec 06, 2015 2:06 pm
Yes, about 8 gms lighter with the Fly body. Still more than I'd like (12-16g), but it will have to do..................
Postby Racie35 » Sun Dec 06, 2015 3:54 pm
I was wondering, I have the Carrera. Not sure I can outbuild it's chassis though...it runs pretty good, I'd just add weight. Lazy I guess.
Racie35
Postby walker » Wed Dec 09, 2015 5:21 pm
Does anybody know if there are still free places ?
And - class P - would it be allowed to use a scatchbuilt cassis from styrene or pcb, or have the cassis to be factory made ?
Roland
walker
Postby Audi1 » Thu Dec 10, 2015 9:36 am
Walker, I think the CanAm proxy is still open. PM shotgundave to get a definitive answer. For the P Class, I think that any plastic chassis is legal; from RTR to scratch built and everything in between.
Postby walker » Thu Dec 10, 2015 11:02 am
Thanks Allan,
Shotgundave had advised me to PM Tusco Todd, because he would be in charge of it now.
I sent him three PM between 5th and 9th, but no answer.
Regards, Roland
Have you seen my PM about the Ford ?
walker
Postby TuscoTodd » Thu Dec 10, 2015 9:44 pm
Postby walker » Sat Dec 12, 2015 3:30 pm
walker
Postby Beast Lee » Sat Dec 12, 2015 4:41 pm
Diggin' this build... :music-rockout:
Beast Lee
Postby bill from nh » Sat Dec 12, 2015 8:23 pm
bill from nh
Postby TuscoTodd » Sat Dec 12, 2015 8:50 pm
Bill - there is nothing preventing it (so long as it doesn't effect structural integrity etc) :)
Postby Pappy » Sun Dec 13, 2015 6:45 am
Allen,
You can do what Bill from NH said about making that U bend and then use a piece of brass tubing to connect the two pieces. After it's soldered just grind the bottom of the tubing off so the wires lay flat. It would make the solder joint stronger.
Use some sort of wheel blank to make sure the axle is perfectly horizontal to the jig, don't trust that the bracket is perfect. You can use old gears for wheel blanks if you don't have any.
If you think you are going to do a lot of scratch building get yourself a set of these pliers. http://www.micromark.com/metal-forming- ... ,7068.html The one at the top of the picture really makes bending piano wire easy.
Pappy
Postby Audi1 » Sun Dec 13, 2015 8:38 am
Thanks Butch, I have that set of pliers and the one at the top is the one that made the box bend in the piano wire main frame in my pics.
Thanks also for the idea on joining two L-bends to form a U-bend.
I'm coming along slowly on this build and probably won't have much more to show before the start of 2016. I have the brass pieces cut out for the center section of the chassis; rear platform, mid platform, guide tongue platform and guide holder. No soldering yet......................
Postby Z-carfan » Wed Dec 23, 2015 1:04 pm
before I hijack the thread, are we posting all builds here for this Proxy?
Postby Audi1 » Wed Dec 23, 2015 9:05 pm
Yes, that was the reason for putting up this thread. Go ahead and post any and all builds for this proxy here.
