Home Racing World • View topic - HRW Land Speed & Drag fun run!
Re: HRW Land Speed & Drag fun run!
Postby TuscoTodd » Fri May 15, 2015 12:40 pm
Postby Racie35 » Fri May 15, 2015 7:29 pm
Been playing with this chassis today trying to get it to go. Though it's smooth as silk it deslots when powered quickly. Limitless bugger just pops up fast and it's done. I may hafta build another more conventional car. Drop arm on this one is really free so I wonder if weight on it would help?
Racie35
Double posted...oops. Btw gears I've tried....9/27. 9/28
Racie35
Postby TuscoTodd » Fri May 15, 2015 7:52 pm
As an added item to also consider, if you are looking to place a fuel tank up front similar to the car below - you could add some inconspicuous weight to the front of the car to minimize it's tendency to pop up?
Postby Racie35 » Fri May 15, 2015 8:34 pm
Thankyou both...what I just did was tape the drop arm and added 13 grams to the chassis front...goofy thing is a missile! In the morning I'll try to get it worked out with the drop arm free...thanks again
Racie35
Postby Racie35 » Fri May 15, 2015 8:45 pm
Btw....I tested with 20mm tall silicones ...I'm still waiting on my urethanes
Racie35
Postby TuscoTodd » Sat May 16, 2015 4:36 am
I like it Dave! :D
Postby Racie35 » Sat May 16, 2015 6:13 am
The vw is cool :banana-dance:
Racie35
Postby DixonJohn » Sat May 16, 2015 7:04 am
What color is that??? Thats sharp
DixonJohn
"The Mayor"
Postby charley » Sat May 16, 2015 8:05 pm
Are commercialy made rear ends allowed? ( rear motor box with the axle mounts made on them )
charley
Postby TuscoTodd » Sat May 16, 2015 10:57 pm
Charley -
If you are referring to a factory made motor bracket like one of the ones below - those ARE completely acceptable: :handgestures-thumbup:
If you are talking the factory drag chassis components / assemblies like below - then no - those are not allowed.
Hopefully that clarifies things.
If not - please let me know.
Thanks!
Todd
Samples of what is NOT allowed: :handgestures-thumbdown:
Postby charley » Sun May 17, 2015 6:06 am
Yep, that's the one. Just wondering. Guess I better get the "old" thinking cap back out and see what I can come up with.
Thanks,
Charley
charley
Postby bookie » Sun May 17, 2015 7:12 am
bookie
Postby Racie35 » Sun May 17, 2015 7:29 am
I agree...a motor bracket isn't a chassis and that's not made specifically for drags. There are some that are though,you probably can't use them.
Racie35
Postby TuscoTodd » Sun May 17, 2015 9:06 am
Sorry about that - I meant to say "Yes" the standard motor brackets are allowed - what isn't allowed is the pre-made drag specific stuff similar to this: http://www.ncphobbies.com/jds-1/24-chas ... r/jds2013/
(that is a full drag chassis - but they also offer just the "back half" etc)
Hopefully that helps clarify things.
Sorry for any confusion!
(I have revised my reply above to make it a bit clearer as well) :)
