Home Racing World • View topic - P-BOP A Parts Box Open Proxy Idea
Re: P-BOP A Parts Box Open Proxy Idea
Postby strangebrew » Fri Aug 08, 2014 1:54 pm
strangebrew
Postby Retro Racer 44 » Fri Aug 08, 2014 3:12 pm
Hi Strangebrew;
Your cars look great and I love the old jalopy pics. They remind me of racing at the Grandstand at the CNE when I was a teen in Toronto. The track was the size of a football field, maybe 1/4 mile at the most.
Here are my suggestions for running a race. First off, use your 12v setting.
If you have four lanes and four drivers, line up the cars beside the track and rotate them through a heat on each lane, approx 2-3 minutes per heat. The drivers race the same lane for the whole event and don't move. That way it is fair across the session.
It works best to have one person handling the recording and car shuffling and four drivers, and a marshal or two if needed.
If you don't have enough volunteers run longer heats on fewer lanes. For example, if only two drivers, you could either run two lanes then the drivers move to the other two, or only run two lanes and about 4-6 minute heats.
If you are all by your lonesome, you can still run a proxy, only you run all the cars in turn on lane one and then move to lane two etc.
Generally in proxies I have done, the total time per car averages about 10 minutes. That is enough to make it worth doing. It could be longer if you are keen and there are not too many cars. I was a driver for the SCX Rally proxy on Auslot that had between 40-50 cars. We had to shorten the time to get it done in one session, but it worked using my first suggestion above.
Anyway, let me know and I will add your name to the track list.
Cheers,
Keith
Retro Racer 44
Postby Slot Therapist » Fri Aug 15, 2014 7:47 am
I have everything together. The only parts I needed to buy was the urethane tires, the tongue, and motor mount. I hope you'll still allow me to participate.
Slot Therapist
Postby TuscoTodd » Fri Aug 15, 2014 7:55 am
Nope Terry - you are denied! :)
In all seriousness though - I think the spirit of this proxy was to try to use things that have been sitting collecting dust in the ol' parts bin as much as possible - and if you have to buy a couple pieces to finish it, it should be all good - as long as you dump them in your "parts box" first - before installing them on the car. :D
Looking forward to getting back to work on mine hopefully later this weekend!
Postby Slot Therapist » Sun Aug 17, 2014 6:00 am
What's the criteria for hosting a race?
Slot Therapist
Postby strangebrew » Mon Aug 18, 2014 6:59 pm
strangebrew
Postby TuscoTodd » Mon Aug 18, 2014 7:14 pm
WOW! Those are some sweet looking rides! It looks like we are going to have quite a varied field! :D
Should make for some cool cars to run and give everyone some different ideas on things to "create" down the road!
(I love the cut down / resized bodies you did!) :D
Postby Slot Therapist » Wed Aug 20, 2014 6:21 am
Definitely going to be a good looking field. :banana-dance: :banana-dance: :banana-dance: :banana-dance: :banana-dance:
Slot Therapist
Postby Retro Racer 44 » Wed Aug 20, 2014 10:51 am
My intent for this proxy was to let people use whatever they had or needed, so they didn't have to go out and buy a certain brand of motor, wheels tires etc. That does not prevent someone from buying everything they need, and then it will be a parts bag car.
Slot Therapist- re hosting an event, see my comments to Strangebrew above, (Aug 8th) and ask away if you still need any answers.
Cheers,
Keith
Retro Racer 44
Postby Slot Therapist » Thu Aug 21, 2014 2:47 pm
Thanks Keith. I definitely won't let you guys down. Todd got a sneak peak of my car. I think all of you will love the Ohio cars.
Slot Therapist
Postby Retro Racer 44 » Thu Sep 04, 2014 11:47 pm
Strangebrew;
I just re-read your post above re cleaning tires. With urethane tires there are several different ways the guys in our club clean them. Some keep a damp cloth with them and after each heat wipe them, some lick their thumbs and wipe the tires until dry and clean, and most use a sanding block to give the tires a bit of a buff if the traction goes off. If you don't have a sanding station set up, you can just take a sheet of medium grit sandpaper, slip it under the car on the track, hold both the car and the paper and give it a bit of power. It doesn't take much.
All that said however, if you are using a track that usually runs silicones, or spongies with goop on the tires, you may have a bit more of a problem. We don't usually worry about the "rubber" urethane dust on the track, but we only run urethane or rubber. A few years ago the CanAm proxy ran sillies on Luf's Targa and it was a disaster. Even with meticulous cleaning of the track, the tires went off to the point the race could not be run, and we suffered with a slippery club track for weeks.
Hope that helps.
Keith
Retro Racer 44
Postby strangebrew » Mon Sep 08, 2014 12:58 pm
I guess that lets me out of the hosting deal. I've run mostly silicone coated & straight sponges for years, seldom used any tire glue.
once in a while rubbed them up witha' dab of STP. I cleaned the track pretty well with laquer thinner. It isn't dirty or gummy
to the touch. As I said, it's masonite with a pretty shinny enamel paint. I've run 150 laps at a pretty good clip with my white coupe
without an off. It has the wide shore 40 urethane tires I cast myself, but the last 100 laps you have to be careful. It starts drifting more.
It is a small banked oval, so once you get into your rythm, it's not too tuff.
Maybe I'll do a video & you can decide if its too slick.
strangebrew
Postby TuscoTodd » Fri Oct 03, 2014 5:25 am
Dave - that is definitely looking cool!
Postby Retro Racer 44 » Fri Oct 03, 2014 5:46 pm
Very nice looking build, Dave. I will be following this one, and thanks for the plug. I will be contacting those who previously expressed interest to confirm entrants and hosts.
I have access to several tracks here and if we don't get enough in the US, we can for sure make a run of it here. One possible track is Luf's old bullring. It is a three lane oval whose lanes cross each other, on a 4 x 8 sheet of mdf, seen here. It would be a blast with these cars, just like old time jalopy racing, eh?
http://www.oldslotracer.com/Bullring1.html
I hope we still have enough interest to do this, as it should be lot's of fun.
Keith
Retro Racer 44
Postby btaylor » Sun Oct 12, 2014 10:59 am
If These boys qualify Im in. MPC Bodies,Artin chassis Carrera wheels and axles, Parts box drivers and everything else homemade.Image
