Home Racing World • View topic - Anglewinder pod for the FC130 motors
Postby Modlerbob » Fri Feb 05, 2016 10:29 pm
I've been experimenting around for a couple of weeks now using a FC130 motor in a slot.it anglewinder pod with great results. The motor is supported on the can end only using the screw holes provided in most FC130 motors. These motors, at least the 21.5k rpm type, don't have so much torque as to cause wheel hop problems and they have a velvety smooth power band with quick acceleration on my mdf track. Several of my cars that had either flat 6 motors (Porsche 911 GT1 98) or other high rpm FK180 motors such as in my MrSlotCar McLaren F1GTR run much smoother now and are turning quicker laps. The top end on the straights may be a little slower but the handling in the corners more than makes up for it. I wonder if Slot.It could be persuaded to manufacture a motor pod for the FC130 motor in the anglewinder configuration. I think if others of you tried setting up a FC130 motor in an existing anglewinder pod you will appreciate the difference as I have. I think Marty Stanley has been conducting experiments along the same line too.
Re: Anglewinder pod for the FC130 motors
Postby nhdungeonracer » Sat Feb 06, 2016 9:06 am
Postby Modlerbob » Sat Feb 06, 2016 9:37 am
So far I'm not noticing any bad handling effects from the motor not being centered. I never noticed any ill effects on my 1/24th scale anglewinders and none of them were ever centered in the chassis. If I do encounter any bad handling which can be attributed to the motor offset I'll try adding some weight to the other side of the car.
Postby Audi1 » Sat Feb 06, 2016 11:06 am
B-nova used to make an adapter that I think they call Additude; which let you use FC-130 cans in pods designed for long can motors.
Postby Abarth Mike » Mon Feb 08, 2016 12:51 am
Both MB Slot and Avant Slot make long can to short can adapters.
Nowadays you can retrofit most cars to modern or different motors. Even SCX gear driven 4x4 :o
Abarth Mike
Postby Modlerbob » Mon Feb 08, 2016 8:06 am
OK, that's who makes them but who carries the parts? None of the online stores I know of has those parts.
Postby Abarth Mike » Mon Feb 08, 2016 8:30 am
Abarth Mike
