Home Racing World • View topic - 3D Chassis
3D Chassis
3D Chassis
Postby frank9129 » Thu Dec 13, 2018 2:19 pm
Merry Christmas to All 'Yall,
Some time ago there was a thread about an Artin 3D chassis.
The library here in Annapolis has a 3d printer. It is there for the public to use. Needless to say it does not get a lot of action.
Does anyone have program for a Artin like chassis I can obtain?
frank9129
Re: 3D Chassis
Postby lancelotalove » Thu Dec 13, 2018 2:27 pm
lancelotalove
Re: 3D Chassis
Postby chappyman66 » Thu Dec 13, 2018 3:33 pm
It's noted in the Thingiverse listing, but be advised that there are two chassis files.
One is for motors with the pinion by the plastic endbell (endbell drive) and the other is for motors with the pinion on the bearing end of the shaft (can drive).
Of course if you have a double shaft motor then it doesn't matter. Lol
Other than the orientation of the motor mount the two versions are identical.
If you print and try it, let me know!
Re: 3D Chassis
Postby Modlerbob » Thu Dec 13, 2018 4:04 pm
Does the person have to pay for or provide the raw material?
Re: 3D Chassis
Postby frank9129 » Thu Dec 13, 2018 8:51 pm
Bob,
At this time the county is providing the supplies. I'm not sure if you can make multiple projects.
I'm going to check it out Saturday.
Lance,
Can I just down the file, or do I have to buy it? If I can get it to work It will be worth 1/2 the price.
Thank you Guys,
frank9129
Re: 3D Chassis
Postby chappyman66 » Thu Dec 13, 2018 9:22 pm
Thingiverse is free....you don't need to pay for the file.
Re: 3D Chassis
Postby noddaz » Thu Dec 27, 2018 9:32 pm
OK Frank, how did it go?
Scott
noddaz
Re: 3D Chassis
Postby btaylor » Fri Dec 28, 2018 4:50 am
I have printed Chappyman's Artin chassis, actually a couple of them. they are spot on with one exception. the front body mount is off. its to far forward to mount an original Artin body. As a scratch build chassis, it is perfect. The motor fits snug, the axle bushing area is just right, and the front dual axle mounts are heavy duty.
The front mount could be cut off and epoxied back after shortening I believe.
12/3/18 - 3D printing service is temporarily suspended.
Postby noddaz » Fri Dec 28, 2018 10:14 am
Well now. Printer is closed temporarily. Sad face.
Scott
noddaz
Re: 3D Chassis
Postby chappyman66 » Fri Dec 28, 2018 10:57 am
Bob,
Great feedback, thank you! That's exactly what I needed to hear.
Any estimate on how far off it is? I am happy to make it right.
Re: 3D Chassis
Postby btaylor » Fri Dec 28, 2018 12:44 pm
Re: 3D Chassis
Postby chappyman66 » Fri Dec 28, 2018 1:47 pm
Excellent. I will check as well once I get home. Once it's right, I will upload the corrected files.
Re: 3D Chassis
Postby frank9129 » Fri Dec 28, 2018 4:04 pm
Like Scot reported, the printer is no longer available.
I'll check with a friend at the library.
frank9129
Re: 3D Chassis
Postby chappyman66 » Fri Dec 28, 2018 6:57 pm
OK....New files are uploaded. Should be correct now....hopefully it works for folks.
Re: 3D Chassis
Postby btaylor » Sat Dec 29, 2018 12:08 pm
I was just about to post the variant on this chassis. I measured the front mount to be off 4mm. But the guide would interfere with that adjustment. The front axle location could go back 2mm to be perfect. Hope this helps!
