Home Racing World • View topic - Glued on tires ?
Glued on tires ?
Glued on tires ?
Postby bobbyraz49 » Thu Oct 23, 2014 6:26 pm
I race Scalextric Trans-Am cars on a Carrera track. My rear tires seem to come off a bit after a crash !
Suggestions for what type of glue is needed.
We ran 2 races today...I came in 4th of 11 in 1st race and 3rd out of 9 in the 2nd race.
The 2 guys that ALWAYS come in the top 2 are untouchable. Their cars seem so much faster than the rest of us. We have checked all cars and all are "stock" motors.
bobbyraz49
Re: Glued on tires ?
Postby HomeRacingWorld » Thu Oct 23, 2014 6:27 pm
On a stock wheel I would use clear nail polish.
Postby bobbyraz49 » Thu Oct 23, 2014 6:46 pm
bobbyraz49
Postby HomeRacingWorld » Thu Oct 23, 2014 7:56 pm
Postby Abarth Mike » Thu Oct 23, 2014 8:52 pm
If the tires are loose rather than sloppy, el cheapo hair spray as used to install motorbike handle bar grips. Takes a while to dry.
Abarth Mike
Postby Cincyslots » Fri Oct 24, 2014 5:20 am
With silicone tires we glue them on with household clear silicone. This with you can reused the tire when needed.
Bruce
Cincyslots
Postby RichD » Fri Oct 24, 2014 6:30 am
If you use glue that is too thick it will be difficult to spread it around evenly. If the glue is not even the tire will be distorted and will have to be trued for the best performance. Some tires are easy to true, but Super Tires are quite difficult to true. Even with a more sophisticated machine, like a Hudy, truing a distorted Super Tire is a tedious business. Most of the guys that I race with use IC2000. IC2000 does not keep well, it is best to store it in a refrigerator.
Postby bobbyraz49 » Fri Oct 24, 2014 10:00 am
Thanks ALL !!!
bobbyraz49
