Home Racing World • View topic - Carrera GO! Speed Controllers....
Postby jp823 » Wed Nov 13, 2013 6:09 am
I have yet to purchase a Carrera GO slot car track, because I'm wondering if it is possible to modify the speed controller so I can regulate the throttle. For instance I currently have an SCX slot car set and was able to drill a small hole in the trigger and insert a small plastic dowel so my 3 yr old son can't squeeze the trigger all the way down. I see the Carrera speed controller is quite different and wanted to know if it was possible to do something similar or can I in some way use the same style controller the SCX set has on the Carrera set?
Any help is appreciated.!
jp823
Re: Carrera GO! Speed Controllers....
Postby LloydL » Wed Nov 13, 2013 7:50 am
Welcome to HRW, I am sure you will get some good advice on here!
Regards, Lloyd
LloydL
Postby OL Mike » Wed Nov 13, 2013 8:42 am
Image this should work
OL Mike
Postby Dodgefarmer » Wed Nov 13, 2013 10:57 am
Some Go controllers have a clip on piece under the thumb pad.
Randy
Dodgefarmer
Postby Cjent » Wed Nov 13, 2013 11:00 am
:text-welcomewave:
You have good answers already!
Cjent
Postby jp823 » Wed Nov 13, 2013 11:53 am
jp823
Postby jp823 » Wed Nov 13, 2013 12:02 pm
One more question...I'm sure this set doesn't appeal to most of you guys, but have you heard anything good or bad about the Mario Kart 7 Carrera GO set? That's the one I'm thinking of purchasing. As I mentioned I have the SCX compact Tri-Oval set, but other than that the slot car scene is pretty new to me...I'm more into 1/10 scale RC's, trail rigs and crawlers....
jp823
