I have yet to purchase a Carrera GO slot car track, because I'm wondering if it is possible to modify the speed controller so I can regulate the throttle. For instance I currently have an SCX slot car set and was able to drill a small hole in the trigger and insert a small plastic dowel so my 3 yr old son can't squeeze the trigger all the way down. I see the Carrera speed controller is quite different and wanted to know if it was possible to do something similar or can I in some way use the same style controller the SCX set has on the Carrera set?
Any help is appreciated.!
