Home Racing World • View topic - Can-Am Proxy 2018 - Tracks
Re: Can-Am Proxy 2018 - Tracks
Postby Pappy » Mon Jan 08, 2018 12:17 pm
Hi Allan,
Put me down for the Midwest race #3. We'll either run it at my track or Pat's track.
Pappy
Postby Oscar Racing » Mon Jan 08, 2018 12:31 pm
Yes, Butch's track is a great place to run...site of the "2018 Orange Barrel Clash!!!!" which Michigan will win again....
Oscar Racing
Postby Audi1 » Mon Jan 08, 2018 3:13 pm
Postby Audi1 » Mon Jan 08, 2018 3:16 pm
Thanks Alwyn and Roger! Looks like it will be a great Round at Maple Ridge.
Postby Pappy » Mon Jan 08, 2018 3:18 pm
Pappy
Postby Audi1 » Mon Jan 08, 2018 3:20 pm
This is Canfield Green, chappy's track in Picton, Ontario.
Here are the particulars on the track:
3 lane routed mdf
Acrylic paint with copper tape
90 feet 4 inches average lane length
3/8ths inch difference between the longest and shortest lane
24 foot big front straight
Power is adjustable to 24 volts and 20 amps
Chappy, feel free to add more, if you'd like. What voltage do you usually run at for cars in the 22k rpm range at 12V?
Postby chappy » Mon Jan 08, 2018 3:35 pm
Always run at 10.5 volts at the Green
Tippy cars are dead on this track especially at the esses.
It needs a lot of legs to get the most out of the straight and long sweeper at the end.
The Can Am cars should run in the 8 second plus zone.
Postby Audi1 » Mon Jan 08, 2018 3:49 pm
This is Bob's (mether05) track in South Grafton, MA. I've raced here and it is one nice track!
Here are the particular on the track:
4 lanes routed mfd with copper tape rails
Surface flat latex
Track length: 75′ to 83′
Runs at 10V
Postby Audi1 » Mon Jan 08, 2018 3:56 pm
This is Christian's (cgingras) track, Circuit Courville. I think it's a, Steve Ogilvie track, but I may be mistaken.
4 lanes, copper braid
Smooth surface
Race Coordinator software, TrackMate interface
Is usually run at around 10 volts (very little resistance in the wiring, so it feels like 11.5 or 12 volts!). 20 amps on the power supply, no problem there.
Very technical track with a faster section.
Postby Audi1 » Mon Jan 08, 2018 4:16 pm
This is The River Run (Audi1) in Merrimac, MA
Those knees belong to Bon Bianchi (Slot Car Corner)............!
This is the Changing.Gearz team running the first PanAmericana cars; left Matt (changing.gearz), middle Bob (rleog) and right Jeff (dge467). Matt's son is in the extreme upper left and I'm behind the computer at the bottom of the pic.
Routed mfd, 65' average lane length
Copper braid rails
Flat latex surface
Race voltage for cars in the 22k rpm/12V motor range is 10V
Postby gascarnut » Mon Jan 08, 2018 4:49 pm
Is Christian going to be OK with running rubber and urethane tires on his (presumably) silicone-only track? Are there other tracks where usually only silicone tires are used?
Also on tracks with braid, how many use Magnabraid, and will that have an effect on whether people will be allowed to use long can motors with the big openings?
gascarnut
Postby Audi1 » Mon Jan 08, 2018 7:01 pm
I'll leave that to Christian to answer, but I think that he has run some non-silicone tire proxies for us in the past with good results. If that's not the case, then I'm sure he'll tell us, in which case we would look for another track.
I would also ask the track hosts to chime in as to whether or not they use Magnabraid. I know that I do not use it at my track
Postby SuperSlab » Mon Jan 08, 2018 10:29 pm
Just to advise that Roger's track has copper tape and individually adjustable power supplies per lane. Any voltage (within reason of course!) is available. 10 - 11V seems to work fine, depending on motor power.
Alwyn
SuperSlab
Postby cgingras » Fri Jan 12, 2018 11:49 am
cgingras
Postby cgingras » Fri Jan 12, 2018 11:52 am
cgingras
Return to MRollingThunder Can-Am Proxy 2018
