Home Racing World • View topic - Removing Decorations
Custom Paint Job Showcase
Postby bookie » Wed Jan 21, 2015 6:14 pm
I know this will be a strange question to most, but I don't know. I see the stock bodies
that are prepped for a repaint and all the chrome and do dads are absent. I recently took a car apart and noticed these parts appeared to be secured to the bodies by welding plastic. How do you remove these "welds" enabling the components removal and then, when all done, how are they best resecured. :oops:
bookie
Re: Removing Decorations
Postby Ember » Wed Jan 21, 2015 6:22 pm
Carefully. :)
A sharp knife and patience are usually the go. I try to cut away the excess 'welded' plastic and free up the 'pin' section and push it out.
Some brands, like Scalextri, actually glue parts rather than plastic weld. And that's a PiTA.
Reattaching I usually do with PVA glue or, more often, Formula 560 Canopy Glue.
Postby TsgtRet » Wed Jan 21, 2015 10:58 pm
Kind of like Shotgun, I use the edge if a worn down cutting wheel in my Dremel on low speed with a light touch to grind away the welds. Gorilla Super Glue gel to reattach.
Postby HomeRacingWorld » Wed Jan 21, 2015 11:02 pm
Me too. I use the 3/32nd or 1/16 milling bits.
Postby Cincyslots » Thu Jan 22, 2015 7:03 am
I use a dremel and 2 way epoxy.
Bruce
Cincyslots
Postby bookie » Thu Jan 22, 2015 9:43 am
Thanks all, info really appreciated
bookie
Postby goosenapper » Thu Jan 22, 2015 9:56 am
goosenapper
Postby Ember » Thu Jan 22, 2015 3:33 pm
Yay. Here was me thinking I was too careful. But you got it in one. I just know I'd finish up with major damage.
Ninco and SCX are my favourites for stripping down. But I have Ninco cars that have been almost impossible to get the paint off and others that have been no problem at all.
Postby bookie » Thu Jan 22, 2015 5:35 pm
bookie
Postby ecr » Thu Feb 19, 2015 10:12 pm
The dremmel, for me is also TOO FAST, so I run it through a dimmer switch and receptacle mounted on a wooden board, so I can turn the rpm down and use the tool much more controlable
ecr :character-oldtimer:
ecr
Return to The Paint Booth
