Home Racing World • View topic - Resin filling, What can I use
Re: Resin filling, What can I use
Postby cagee13 » Sat Mar 07, 2015 10:09 am
I use tamiya putty
cagee13
Postby RichD » Sat Mar 07, 2015 11:13 am
I used to use Testors putty, but the last few tubes of it that I have bought had separated and was useless. I guess it does not like sitting on the shelf too long before it is sold. I will have to look for Tamiya or Squadron putty. There is only one real hobby shop left in my area, I would hate to have to order just a tube of putty.
Postby Nor Cal Mike » Sat Mar 07, 2015 11:19 am
If it is structural, spans some distance, or in a critical location. I use JB Weld and follow up if necessary with White Putty to finish the final contour. If it is simply filling a minor blem the White Putty is my favorite.
Nor Cal Mike
Postby HomeRacingWorld » Sat Mar 07, 2015 1:49 pm
Postby bill from nh » Sun Mar 08, 2015 5:48 pm
Mark, care to share your alternative here?
bill from nh
Postby 4424ever » Sun Mar 08, 2015 9:53 pm
I've used CA with bakingsoda works like a charm !
4424ever
Postby Abarth Mike » Sun Mar 08, 2015 11:10 pm
I will add my vote for Tamiya Epoxy Putty. Sets very slowly and can be sculpted after a few hours then left overnight and sanded.
If it is not structural and you want the modelling equivalent of "Bondo" to fill in some imperfections use Tamiya Putty. It is only one part and a bit more "runny"
Abarth Mike
Postby Retro Racer 44 » Mon Mar 09, 2015 12:51 am
Hi Mark:
I was wondering if that was the car you were working on. I'm looking forward to seeing it finished. I was going to say that baking soda with CA makes a gap filling CA. It also sets immediately as the baking soda acts as a catalyst to the CA. I would rub some soda in the void and drop the CA on it to fill. You can repeat if necessary, and if the void is at a structurally needy place, it will glue it together as well.
Cheers,
Keith
Retro Racer 44
