Home Racing World • View topic - Power Supply advice needed!
Postby racer1h » Sun Apr 26, 2015 9:20 am
racer1h
Re: Power Supply advice needed!
Postby racer1h » Sun Apr 26, 2015 12:24 pm
Thanks...just ordered 2 of the Tekpower units.
racer1h
Postby rocky top racer » Sun Apr 26, 2015 12:48 pm
Is there a negative ground version available or a simple conversion to hook up to Ninco terminal track? Keep in mind, I am no electrician, either.
rocky top racer
Postby ccobra » Sun Apr 26, 2015 12:53 pm
ccobra
Postby slowshoes » Sun Apr 26, 2015 4:00 pm
So I still don't understand how those power controllers are wired into a given set up. Does it matter if your using wireless controllers? Any elaboration would be appreciated so I don't end up doing something real dumb - like starting a fire and burning my house down! :o
slowshoes
Postby ccobra » Sun Apr 26, 2015 4:34 pm
My simplified version: Image Of course I took a short cut on my wiring diagram after the Digital Voltmeter. At this point you just wire back into the track wiring, nothing tricky here. The Voltmeters were added just for the wow effect for the grandkids for after setting the current draw from the cars will make the digital readout vary, just like a digital tach.
ccobra
Postby slowshoes » Sun Apr 26, 2015 6:09 pm
Thanks for the welcome ShotgunDave and the wiring diagram ccobra. I'm using a Ninco track with wireless controllers. I can turn the power from a high to low setting, but I have no way to dial it in to a specific voltage, which seems like a neat thing to be able to do. I never race with magnets, so newbies can still get themselves into trouble, even on the low setting. (the manual doesn't state how many volts the low setting actually is.
It'll be awhile before grand kids are racing, as my oldest daughter is pregnant with her first baby (and our first grandchild) right now. Feels good to be back into slots after a hiatus of about 40 years. :)
slowshoes
Postby ccobra » Sun Apr 26, 2015 6:57 pm
I don't mean to scare you but those kids grow up really fast, just like slot cars :)
ccobra
Postby chappyman66 » Sun Apr 26, 2015 9:38 pm
You might be surprised.....my 3.5 year old grandson gave Papa a run for his money last summer. He learned about going half speed to stay in the slot and if you run hard and slide a bit in the corners, it's pretty hard to keep up. Teaches you a lot about smooth driving......tail wagging looks fun but's it actually slow!
So yes.......you might be needing those power supplies sooner than you think!
Postby slowshoes » Mon Apr 27, 2015 9:23 am
slowshoes
Postby pgtr » Mon Apr 27, 2015 8:14 pm
pgtr
Postby ccobra » Mon Apr 27, 2015 8:37 pm
I got the ones that were completely variable, 0-13.9 v since that is the maximum output of my regulated power supplies.
ccobra
