Home Racing World • View topic - HRW Land Speed & Drag fun run!
Re: HRW Land Speed & Drag fun run!
Postby Racie35 » Mon May 11, 2015 2:27 pm
Setting on the chassis
Racie35
Postby Racie35 » Mon May 11, 2015 4:35 pm
You'll need a 1/32 body...but if you have tube type cars you can do a slingshot dragster easy enough. I just built one from brass,copying smaller one I had here. It's easier when you're not designing.
Post a few pics of what you're considering,and their chassis'
Racie35
Postby TuscoTodd » Mon May 11, 2015 4:52 pm
Postby Racie35 » Mon May 11, 2015 6:05 pm
Thanks for posting the links! Ole shotgun had em covered didn't he!
Racie35
Postby TuscoTodd » Mon May 11, 2015 6:20 pm
Yeah Dave's car was quick both out of the hole and on the top end - but similar to the regular racing, each car had it's own personalities and definitely made for some good entertainment! :)
REALLY looking forward to seeing what everyone enters in this! :D
Postby Racie35 » Mon May 11, 2015 6:28 pm
That traction deslot in the one video ....worrisome
Racie35
Postby Racie35 » Mon May 11, 2015 7:14 pm
What gearing was it? Motor and tires too!
Racie35
Postby TuscoTodd » Mon May 11, 2015 7:51 pm
Postby TuscoTodd » Tue May 12, 2015 8:10 am
Postby btaylor » Tue May 12, 2015 8:19 am
This is going to be a good one!
Cant wait to see the cars in this race.
Postby Ky.Slot Racer » Tue May 12, 2015 4:12 pm
Ky.Slot Racer
HRW Master Modeler
Postby Racie35 » Tue May 12, 2015 5:19 pm
Yes but is there only one track being used in this fun run? All voltages will vary or no?
Cool your tests are going good, post us a video!
Racie35
Postby btaylor » Tue May 12, 2015 5:47 pm
Glad you had some good test time Mark! its nice to know you wont be flying off the track at fifty feet!
I got the tire issue fixed on my A class liner too, they were loosing shape badly, but not coming off.
Postby Racie35 » Tue May 12, 2015 6:20 pm
I can't answer your body question but there are only 2 allowed motors and the 40,000 hr isn't in each class....the other piranha all but the slingshot I believe because there's 2 classes of LSR. Both motors are under $10
Racie35
Postby Ky.Slot Racer » Tue May 12, 2015 6:23 pm
sounds a little big Dave, real car 54" wide so 1/32 scale should be around 1.68" i believe. I suppose that`s up to the originator of the fun run.
Ky.Slot Racer
HRW Master Modeler
