by TuscoTodd » Mon Jul 20, 2015 8:43 pm
Arrold - I think your car is going to like TurboKev's track as I think the banking here is what was giving your car fits. As you can see in the videos, it has good speed, but if you pushed a bit too much it would go from smooth drift to chatter and work at slipping the guide from the slot coming onto the straight. I'm not sure if a little less rear bite, or a little lead up front might not cure that issue?
(Kev may have more insight on this?)
Also, Steve asked me to change up his gearing before the cars rolled out, so his car are now sporting 8-30 gears as well. Should make for some good close racing! :D
