Well, everybody already said how nice the car turned out and anything else I would have said, so I'll go for the exhausts. Those little suckers are hard to get right. I have that car and when one of them popped off and got lost, I spent way more time than I thought I would getting it replaced. Just as I was about to take the remaining one off because I couldn't make a satisfactory match, the old one turned up. But I was amazed at how hard that was to do. The best solution I came up with was aluminum tubing slightly flared full length with a diamond mini reamer- $3 (
http://www.sciplus.com/p/DIAMONDCOATED- ... MERS_53275), used as a mandrel, then hot glued in place, but as I say, I only made one and then didn't use it. Good luck if you decide to make a do-over on those buggers.
