At one point on this thread, the topic of an aluminum hub crown gear vs. a brass hub came up and, in the end, and after talking with a lot of people, I changed out the aluminum hub for a brass one. I seldomly worry about stripped crowns though, because I use a belt and suspenders approach to keeping the crown and the pinion aligned. Here's a pic that shows what I do for IL motored cars:
If you look closely to the right of the crown face, you'll see three spacers; an 0.02", an 0.05" and another 0.02: on the axle between the crown face and the inside bushing face. This is not a tight fit, I leave just a little play. Then I fine tune with the axle stoppers that you can see on the outside faces of the bushings. It makes for a pretty secure unit. I probably could have stayed with the aluminum hub safely; which I prefer because it weighs less and, therefore, gives less drive train resistance. But, for this car, I went with the brass hub.
Here are a couple pics of the running chassis:
And a couple of the car with the body mounted on the chassis:
It's a fairly light car right now; 70.4g with the chassis mounted to the body. I need to do some tire testing this weekend, followed by some weight testing. Once that's done I can mount the wire wheel inserts and it will be ready to be shipped out for the race. Seems the more time you have, the more tinkering you do...........................
