by vins123 » Sun Nov 29, 2015 1:03 pm
Hi
you did really nice work on those, have you ever tried using an HP7 chassis?
here what i do, i take an HP7 chassis remove the motor and put a Tomy 6 ohm, all you have to do is put the metal tab to the good side and works... i used 440X 2 rear and front axle and you body is already lower about 4 mm in that way, without cutting anything... i did not find yet anything to replace the magnet so far but with two 57 Bel Air mounted the same way why change the magnet!!! thwey are both equal speed, etc...and run really nice.
Sylvain
