Home Racing World • View topic - A little work on the Palmer Divide Raceway
Got Wood?
Your ROUTED TRACK Home!
Re: A little work on the Palmer Divide Raceway
Postby red73mustang » Fri Dec 04, 2015 6:58 am
You really capture the "sadness" of the junkyard resting place. Only thing missing is a junkyard dog chained up by the gate.
red73mustang
Postby dreinecke » Fri Dec 04, 2015 7:24 am
True, but I'd let him wander loose as I'm not a fan of chains. I have thought about a few fuzzy bunnies though.
Postby Nor Cal Mike » Fri Dec 04, 2015 10:38 pm
looks very good sir. You're attention to small detail makes for a very believable scene.
Nor Cal Mike
Postby Dr Dan » Thu Dec 10, 2015 9:54 pm
Not only is the scenery fabulous, the track itself is a work of art.
The elevation changes are my favorite feature.
Looks both fun and challenging !
Dr Dan
Postby dreinecke » Thu Dec 10, 2015 10:32 pm
Thanks folks. Glad you like it. A track is never done and once I get scenery turf down I'll go back to casting more and different figures and stuff. The plan is for many vignettes around the track. I did install a back drop and immediately took it down. It really did not look good and the track is more like furniture now, so oh well!
Postby dreinecke » Thu Dec 10, 2015 10:37 pm
I had a few hours to myself to do some much needed landscaping before family shows up tomorrow night. I got roughly 90% done. I keep the outer edges until last so I can lean over it without causing problems.
The turf is comprised of paint, sanded grout and then I used three types of static grass over all of that. I used WS Autumn 2mm and Silfor 6mm Autumn and late Summer grasses. The trees have been used on all three of my layouts as have the fence parts. This time I tried to make everything a little less perfect than the last track and I think it looks much better. I still plan on more bushes, and a ton more figures, etc. when done.
What the track looks like under construction:
After a quick cleaning:
Postby dreinecke » Fri Dec 11, 2015 8:47 am
Postby Dogsbody » Fri Dec 11, 2015 8:56 am
Dave,
Do you have any sort of construction plans for those bridges or do you just wing it? I need to build a rather wide and tall one (to clear Fly trucks) for my track and it needs to house the timing system as well.
Thanks,
Dogsbody
Postby HomeRacingWorld » Fri Dec 11, 2015 9:03 am
Can't say it enough...just outstanding work.
Postby RazorJon » Fri Dec 11, 2015 1:30 pm
No worries Dave, girls like slots and they can be pretty good from the start
Fine track you have a museum piece
Postby TuscoTodd » Sat Dec 12, 2015 9:12 am
WOW! Dave - that track just keeps looking more and more amazing!
Bravo sir! Bravo!
Postby RV Racing » Sat Dec 12, 2015 12:20 pm
What's the RMS-approved technique on applying the static grass? Do you have one of those static applicators, or just wing it?
Cheers,
Rick V.
RV Racing
Postby dreinecke » Sat Dec 19, 2015 11:44 pm
Postby ratfink03 » Wed Dec 30, 2015 7:10 am
Beautiful track Dave. Love the design and the attention to detail. Inspirational and only hope I can achieve something half as interesting.. Great job.. I was wondering what size white corner barrier did you use and where did you find it.. I'd like to steal your Idea if you do not mind. ( looks like flat plastic) thanks
Robert
ratfink03
Postby slowdogracer » Wed Dec 30, 2015 1:18 pm
That's really an awesome job you did. Great detail especially with the lighting.
slowdogracer
Return to The Lumber Yard
