Route 66 Rally/Raid layout.
SHOW YOUR SLOT CAR TRACK!
Re: Route 66 Rally/Raid layout.
Postby SpeedyNH » Tue Apr 12, 2016 1:20 am
it's always great to see updates to this thread. great work!
speedy
SpeedyNH
Postby downtowndeco » Tue Apr 12, 2016 11:05 pm
Not all O Scale buildings will work. In fact, if you are plan on using them right up front with 1/32 figures it can be tricky. That being said, it is possible. What you need to do is to start w/an O Scale structure that has about 3 1/2" between each floor. That works out to about 9' in 1/32 Scale. A bit small for a commercial structure such as this one, but doable.
The first floor is most important because that's where your doors will be. If needed, add a bit of "foundation" to the entire base of the structure to "raise" it. This building was tall enough, but the doors were too small so I cut them out & kitbashed a new set using a pair of Tichy O Scale doors as a starting point. Using strip styrene & a little cutting & fitting I "stretched" the doors a bit to make them taller. I keep a 1/32 figure close by so I can kind of eyeball it. Probably not too close if this was really scrutinized but close enough for my purposes.
I added a "drop shadow" to the Route 66 sign using a black Sharpie, added a few more signs & the doors & widows.
Image[/URL]
Image[/URL]
Image[/URL]
downtowndeco
Postby Wobble » Tue Apr 12, 2016 11:30 pm
Wow, just been browsing through your thread. Amazing stuff, all of it.
We used to have IGA here in NZ when I was a kid and whatever happened to Wrigleys Spearmint? I was at the supermarket only half an hour ago and noticed 2 types of PK and Juicyfruit but no Spearmint and that was always my favourite.
Wobble
Postby TuscoTodd » Fri Apr 15, 2016 7:45 pm
WOW!!! That looks awesome!
Postby downtowndeco » Sun Apr 17, 2016 6:57 pm
Thanks, glad you guys dig it!
I worked on the layout for a bit today. I added some cracks and tar patching to some of the track. I simply used black craft acrylic paint. Oddly enough it shows up pretty well on the black track. The trick is to making it look real is to have some variety & to not overdo it.
Image[/URL]
A rough placement of the buildings. The buildings all need to be "planted" with foundations. Much more detail will be added & I'll "dirty up" that pure black Main St.
Image[/URL]
Here are some pics of the layout for those who have not dug through all of the pages of this thread. : )
Image[/URL]
Image[/URL]
Image[/URL]
Image[/URL]
Image[/URL]
downtowndeco
Postby downtowndeco » Mon May 09, 2016 3:45 pm
The latest structure. This was entirely scratchbuilt, from the brick walls to the facade & signs for the front of the building. The odd triangle shape is so it fits where I need it to. Questions?
Image[/URL]
Image[/URL]
Image[/URL]
downtowndeco
Postby Beast Lee » Mon May 09, 2016 5:14 pm
Absolutely incredible work... :music-rockout:
I thought that the Texaco station was my favourite, but as I progressed through the pages, I'm left kinda numb...
I have no favourite, as I love what you've done with all the buildings you created...
My hat's off to ya...
All the best...
Ron...
Beast Lee
Postby dreinecke » Mon May 09, 2016 8:25 pm
Absolutely AWESOME!!! I love all your work, but it just keeps getting better!!!
Postby Wobble » Mon May 09, 2016 11:56 pm
You got a contact for the Rocket Motel downtowndeco?
I think I might have to book in for a few days to take a closer look. Just keeps getting better ... if that's possible.
Wobble
Postby downtowndeco » Tue May 17, 2016 9:44 pm
File this under "Do as I say and not as I do..."
When I first started this layout it wasn't really meant to be permanent, I just put a couple of pieces of old 4' x 8' hardboard on a few sawhorses & I figured if I ever had to move the layout I'd just take off the "top" & then reposition it after I moved the sawhorses. I put sliders under the feet to help it slide if I needed to do maintenance or work on scenery. It kind of sort of slid forward or backwards a few feet but really, it was a huge pain in the rear to move.
I finally had enough of that hassle so I built 2 proper "frames" with legs for the pieces of hardboard & slid them underneath the original hardboard sheets. I won't bore you with all of the details but let's just say I can move the whole 16' layout with one hand now. The frame & wheels are the best improvement I've made on the layout to date, but honestly, it should have been the first thing I did. Bad, bad layout builder. : )
Layout w/original sawhorses.
Image[/URL]
I built two of these...
Image[/URL]
... and slid them under the two halves of the layout...
Image[/URL]
...then bolted the two halves back together. It works!
Image[/URL]
downtowndeco
Postby downtowndeco » Wed May 18, 2016 6:43 pm
I added a new sign & some extra detail to behind the old Texaco Station. I finally found a use for all of those old tires.I still need to age it with chalks a bit.The old truck is something from my 1/35 military scrapbox.
Image[/URL]
downtowndeco
Postby Z-carfan » Wed May 18, 2016 6:54 pm
Great work, looks amazing!
Postby downtowndeco » Sun May 22, 2016 7:55 pm
Flying through the desert at dusk!
Image[/URL]
Image[/URL]
My latest car. I added the extra decals to make the Bowler more than a test car. Also, check out the awning w/special Dakar USA logo. : )
Image[/URL]
downtowndeco
Postby dge467 » Sun May 22, 2016 8:46 pm
Looks really nice!
Postby ourwayband » Mon May 23, 2016 11:52 am
Very nice!!
Return to Reader's Roads
