Home Racing World • View topic - Ford Ranchero - slammed like Retro Racer's
For 1/32nd Scale Models
Postby VTECFOUR » Sun Aug 21, 2016 6:49 pm
While waiting for parts in the mail for on my other builds, I've jumped on this Ranchero body that I cast before AMT re-released the original kit.
Retro Racer's slammed version was cool, so I'm going that way. My 55 Chevy re-built chassis turned out well, so I put together a similar one. Again, the Professor Motor motor bracket's fluted bottom edges were uneven, so out came the file. All's even and flat now.
VTECFOUR
Re: Ford Ranchero - slammed like Retro Racer's
Postby dge467 » Sun Aug 21, 2016 7:00 pm
Looking forward to your build!
Postby HomeRacingWorld » Sun Aug 21, 2016 8:00 pm
Another one! I have to get busy. Look forward in seeing this one.
Postby Retro Racer 44 » Sun Aug 21, 2016 8:16 pm
Retro Racer 44
Postby ccobra » Sun Aug 21, 2016 8:28 pm
I've got one of these also on the back burner. I'll be watching this one with full attention. Your builds are always extra good in detailing.
ccobra
Postby waaytoomuchintothis » Sun Aug 21, 2016 9:27 pm
I'm planning a twin set, a Falcon Ranchero and an El Camino, but they are a ways off yet. Watching this one.
Postby VTECFOUR » Sun Aug 21, 2016 9:53 pm
Playing with the ride height.
It'll be close to this.
VTECFOUR
Postby TsgtRet » Sun Aug 21, 2016 10:44 pm
Looking good so far! Uh....will the "ride along crewmembers" be in the final build?
Postby VTECFOUR » Mon Aug 22, 2016 11:58 am
@TsgtRet - Spotted my ride height "spacers", eh. Good eyes.
Mounted the body and got a good stance. Works for me.
Chassis work, next.
VTECFOUR
Postby VTECFOUR » Mon Aug 22, 2016 9:25 pm
Side pans are next. Going with .063 brass but need to cut 1/2" strip down to 3/8".
Modified resin inserts made from Revell's 55 Chevy kits wheels.
Fit them into the 15" Avant Slot fronts and 17" Slot It rear rims.
Thinking of a white finish with red rims like the 1:1 Ranchero currently listed on Bring A Trailer.
VTECFOUR
Postby VTECFOUR » Tue Aug 23, 2016 3:59 pm
Chassis's done.
Parts list includes:
- Fly Racing Rally 18K boxer motor
- SCX Pro 9t pinion
- SCX Pro 26t crown
- Avant Slot 15 x 8 rims/tires unknown at front
- Slot It Slot It 17 x 8 rims/urethane tires
- Professor Motor motor pod
- Slick 7 3/32" x 3/16" bushings
- Slot It rear axle
- piano wire front axle
- Sloting Plus universal guide
- Slot It tinned braid
- Slot It silicone motor wire
Got a feeling that it'll run like my 55 Chevy build.
VTECFOUR
Postby TuscoTodd » Wed Aug 24, 2016 7:40 am
Progress looks great!
:handgestures-thumbup:
Postby VTECFOUR » Fri Aug 26, 2016 9:51 pm
Got some taller profile and narrower PG tires.
No more imminent chassis dragging and the slammed look is retained.
Helps that Paul's a local phone call and only a 15 minute drive.
VTECFOUR
Postby The Blue 7 » Sun Aug 28, 2016 11:11 am
Lookin Good !!!
What did you use for Body Mounts ?
The Blue 7
Postby VTECFOUR » Sun Aug 28, 2016 5:17 pm
For body mounting, I like to use flanged and knurled brass screw inserts mounted into Evergreen styrene tubing epoxied to the body.
My small to medium cars use 2-56 flanged and knurled brass screw inserts and Evergreen 3/16" styrene round tubing, part no. 226 fitted with 2-56 or 2mm screws.
My larger builds use 4-40 flanged and knurled brass screw inserts and Evergreen 7/32" styrene round tubing, part no. 227 with 4-40 screws.
Lately I've been going with a single post at the rear rather than two. I think I get a bit more adjustment range of body rocking but you've got to be careful with tire rubbing on the body.
Works for me.
VTECFOUR
Return to 1/32 Showcase
