Home Racing World • View topic - New "Toy" came today
Postby TsgtRet » Mon Aug 29, 2016 6:18 pm
Re: New "Toy" came today
Postby HomeRacingWorld » Mon Aug 29, 2016 7:22 pm
Good call :)
Postby Z-carfan » Mon Aug 29, 2016 7:42 pm
Great PS there, I am currently using mine for my Tire Razor, until I get the Routed oval done. By done I mean find the time and get all the junk off of it. :)
Postby slothead » Mon Aug 29, 2016 7:43 pm
Nice looking power supply. Is it variable, and if so what's the voltage range?
Thanks.
Slothead
slothead
The Doctor is IN!
Postby TsgtRet » Mon Aug 29, 2016 9:05 pm
Postby Mitch58 » Tue Aug 30, 2016 5:50 am
I bought one about a year ago and it works great. All the time I spent trying to build cars that the smaller grandkids could keep on the track, and now I just turn the voltage down and they can run anything.
Mitch58
Postby BIG E » Tue Aug 30, 2016 9:36 am
WOW! At the buy it now price that thing's a steal! The listing says 30V - 5A, but the back of the unit says 10A. Even better!
That would make a killer low cost multiple use HO power supply for me.
Gotta get one for myself. Thanks for the lead, and good luck! -- Ernie :>)
BIG E
Postby TuscoTodd » Tue Aug 30, 2016 2:06 pm
Postby BIG E » Thu Sep 01, 2016 4:21 pm
Once again, Todd, you found something I was looking for!
I just purchased one of these units today, and even if it is only 5 amps it'll be fine for my intended purpose - to power my Auto World HO drag strip that is used just for FUN racing and promotional events. I basically needed a little more "oomph" on the starting line. I never considered using the AW 13.5 volt unit and immediately started off using an AFX 22 volt wall wart (the Tri Power type). Believe it or not, even with that supply (which is probably .5 amp at best), if two drivers punch it at just about the same time the cars (even stock Aurora Thunderjets) would occasionally "stutter" on the starting line for a few seconds and then finally take off - not fun, especially at the promotional events with newbies. (Of course the track rails and pick up shoes are all clean and in good condition.) That's why I wired two old Aurora 20 volt tan metal box Model Motoring transformers together (which gives me maybe 1 amp at best) and tried that. Seems to be working so far, but for 40 bucks or so delivered to my door I figured I'd give this thing a shot.
Then I did something I usually never do. I looked at some electronic tech reviews on You Tube, and wasn't very encouraged by what I saw. Most of it seemed to be QC issues, like poor solder connections or a slightly loose lens on the front panel, which is no big deal. Like I said, it's gonna be used for FUN, not in the electronics lab or even club racing for that matter. Bad solder joints I can fix myself, and I can have one of the techs at work take a look if I really have a problem. So, for this low price it should serve it's purpose just fine - I'll probably just set it up once at 20 volts and then never touch the knobs again!
We'll see when it gets here in a week or so.
Hope all of us east coasters can have a SAFE and DRY Labor Day weekend. -- Enjoy! -- Ernie :>)
BIG E
Postby Flounder » Thu Sep 01, 2016 10:40 pm
Nice! Looks like a good investment.
Flounder
Postby BIG E » Thu Sep 08, 2016 12:54 pm
The new power supply arrived yesterday, three days ahead of schedule. I opened the top of the box but didn't have time to unpack and start messing around with it. We'll see how it goes once I have a chance to do some testing with the unit. To be continued... Ernie :>)
BIG E
Postby rocky top racer » Fri Sep 09, 2016 10:10 am
Is this power supply negative ground or positive ground? I am quite interested in buying one, but need negative ground for Ninco terminal track. If it is positive ground, is there a simple 2ay to convert?
rocky top racer
Postby TsgtRet » Fri Sep 09, 2016 11:07 am
Postby HomeRacingWorld » Fri Sep 09, 2016 1:37 pm
Raced about any car this past weekend and it continues to work fine.
Postby Jerzeyguy » Tue Nov 22, 2016 12:17 pm
Sorry for the stupid question ......but will this power supply run both lanes ?.....or do I need a single unit pre lane ?? :think: :roll:
Jerzeyguy
