Home Racing World • View topic - Scalextric BMW E30 BTCC 1991
Share Your Thoughts!
Postby HomeRacingWorld » Fri Nov 18, 2016 12:14 pm
Re: Scalextric BMW E30 BTCC 1991
Postby Cosmic Bilby » Sat Jan 07, 2017 6:30 pm
G'day Harry,
Is this the same model as the new Jim Richards John Player Special car?
I'm looking at putting together a Group A field of touring cars to run, a new class. Have the Dick Johnson Shell Sierra and also a Taisan GTR (HPI).
Cosmic Bilby
Postby HomeRacingWorld » Sat Jan 07, 2017 7:48 pm
Yes. Remember these are inline though.
Not a very popular car as you might guess, but it does run pretty good.
One word of caution: I am discovering that the front guide plates are very loose fitting. In fact, rather frustrating. Going to convert both of the BTCC models I have to solid, more reliable Slot.it.
Postby Cosmic Bilby » Sun Jan 08, 2017 5:55 am
G'day H,
I love the review especially the video segment, really good quality stuff there.
Ok I haven't got an issue with the inline layout, it's my favoured set up so all good for me.
I think I'll be using urethane son mine, I like PGT's, probably have something kicking around here at home that will fit the rim.
Is the looseness of the guide plate a wear issue on the moulding die maybe?
That style of guide used to be acceptable, my main issue was always the lack of depth of the blade. I do have some spare guides here that I can swap out if I run into troubles with this one :)
Cosmic Bilby
Postby HomeRacingWorld » Sun Jan 08, 2017 8:16 am
To be honest I have not inspected it close enough to determine the exact cause.
One issue is where the lead wire ends (metal straps) connect to base plate. Very loose and tend to slide outwards, effecting connection.
Blade depth, yes might be an issue. They improved it on the first issue, but changed it back. Reports of it dragging on outdated classic track. A shame really, it's time to move forward and stop worrying about this compatibility.
You should find that getting tires easy enough given the wheel sizes. I'm a PG man myself, but had a surprise with the Quick Slicks Firm blend. The soft and extra firms don't work very well, but this middle blend seems to last. Just a heads up if you feel the need for a silicone option.
Thanks for the feedback. Glad you enjoyed the review.
Return to Product Reviews!
