Home Racing World • View topic - Carrera Go Controller modifications
Re: Carrera Go Controller modifications
Postby Rinkrat99 » Thu Jan 12, 2017 1:37 pm
No love on the photo, trying again
From looks of it, there is a seem around the bottom plate where the plate is glued to the track and potentially three posts under the lid
Rinkrat99
Postby pfuetze » Thu Jan 12, 2017 1:58 pm
i would say - remove screws - pry open with screw driver inserted between the parts?
do not see any other way ...
maybe dremeling away the material around the glued areas
Postby Rinkrat99 » Thu Jan 12, 2017 2:25 pm
Rinkrat99
Postby Rinkrat99 » Thu Jan 12, 2017 2:27 pm
oopps for some reason did not see the previous pics. I have just used some clips to jump the resistors externally so I can test it out. I really would like to know how the others have removed this without damage cause I see bending and damage. I wonder if Carrera modified the tooling to prevent this so we need to purchase thwe Digital version.
Rinkrat99
Postby Rinkrat99 » Sun Jan 15, 2017 10:22 am
FYI Tried jumping out the resistor (33 ohm) in the terminal track using stock Carrera GO controllers and works at eliminating the resistance but seems to be twitchy when driving the GT Competition kit layout. Seems like no adjust ability on thumb control without that 33ohms. Could be reduced to maybe 15/20 ish and see what happens if I can figure how to open that Terminal track without damage. I used spring jumpers on the outside of the terminal housing where the resistor is visible to access the leads to jump out.
Rinkrat99
Postby pfuetze » Mon Jan 16, 2017 2:43 am
if you bypass the resistor in the terminal track, you need to RISE the controller resistor.
between 45 and 60 ohms
carrera evolution controllers work good or ninco controllers (55ohm)
Postby Rinkrat99 » Tue Feb 21, 2017 9:14 pm
Pfuetze,
You recommended the Carrera Evo controller, is it p/n 20709? And Ninco 55 ohm p/n NINCO 55 PLUS CONTROLLER 10310?
Rinkrat99
Postby Rinkrat99 » Tue Feb 21, 2017 10:10 pm
Hi all
Pulled out the 33 ohm resistors and the cars are basically undriveable :mad: with the stock Go controllers. I got the 2nd Terminal track open by prying it open carefully, not too bad with little damage 8-) but can still go back together and run but the resistor was desoldered and replaced with a short. I had trouble keeping it on the track :lol: where a stock setup can drive almost full throttle all the way around minus the BOOST. Maybe go to a 22 ohm or 11 ohm may be more driveable :clap: . It seemed almost choppy with the stock controller and no resistor, not much fun.
Rinkrat99
Postby pfuetze » Wed Feb 22, 2017 12:43 am
Postby Cjent » Wed Feb 22, 2017 8:09 am
Cjent
Postby Rinkrat99 » Wed Feb 22, 2017 8:37 am
Stupid question
What is a DS Basic-2 controller?
Rinkrat99
Postby pfuetze » Wed Feb 22, 2017 11:02 am
resistor controller made by DS
DS also produces tuming systems.
Postby Rinkrat99 » Thu Feb 23, 2017 7:55 am
Hi all
If I purchase two of the Evolution controllers, they come with a 3 pin connector. How does the wiring differ from stock Carrera GO Controllers?
I assume 1 is Power In from track, 2 is power back to track, what is pin 3?
Rinkrat99
Postby pfuetze » Thu Feb 23, 2017 8:52 am
pin 3 is for braking
Postby Rinkrat99 » Thu Feb 23, 2017 9:19 am
Does that pin then go to the TURBO connection from the previous controller?
Rinkrat99
Users browsing this forum: Bing [Bot] and 1 guest
