While the little roadster is in the build off, we found this other hot rod lurking in the corner.
We started working on it also. This is an old vibe body since it has no side bubbles.
We'll just call this one hot rod 2. Started by cutting the front off and trimming it to
fit the chassis. Then cutting the back leaving just the trunk lid intact.
Interior was removed and body lowered on the chassis.
After trimming the body to clear the rear wheels, we started building a rear deck for it.
Sides where filled in with sheet plastic along with the rear.
A notch was made to clear the gear, and the gap between the the side of the deck and the body will also be
filled, which will close the void between the two.
What we have so far looks pretty good. This body is a little rough, with gouge marks all over it and
will take some work to smooth out once the fab work is complete. We will see what happens.
All for now
Kevin
