Hi guys,
Ok I have a supersized update to share. Firstly I must apologise for the lack of updates. Its been about 2 years since I have shared anything. Wow time flies! Yes Im a slacker but I have been working on things, just haven't shared much. I am totally blown away as I have noticed there have been over 16000 page views since I first started this thread. Thanks guys. In replies to Broman's comment. I have checked into HRW most days, just haven't really contributed. Im still here, don't plan on leaving!
In the last 2 years I have got a lot done on Mels Diner. Its been incredibly time consuming as everything is scratchbult & a lot of time is spent researching & playing back the movie. Worked on a few cars & spent a lot of time running the track with the kids. As simple as the track is, it is super fun. Not a design & style I would of thought would be so enjoyable. Also the track got pulled apart & moved into a different room in the house again when the kids wanted different rooms.
Ok update time. Ive got the bulk of Mels Diner completed. Everything painted up. Also little touches for those that know the movie, a phone box, Toads Vespa & the bin Toad ran into etc. A HUGE chunk of time went into the Mels Drive-in sign. In the end I designed Mels Drive-in sign in Adobe Illistrator & the file was sent to a local laser cutting facility. All starting to come together.
Here you can see the Vespa, bin etc
Phone box at the end of parking lot. Just need Kurt's 2CV!
So one thing I didn't mention yet was that the Mels Drive-in sign lights up. This took a lot of work to work out how. I glued the MDF laser cut sign onto the building. I used some 3mm EL Wire superglued onto the Laser cut MDF sign. Holes were drilled into the sign prior & the EL Wire weaves in & out of the sign. Once the EL Wire was glued in place the Perspex was glued on top, so the EL Wire is sandwiched in. Then to finish it off I glued super thin strips of styrene around the out side of the lettering.
Ok that's it for now. Any questions just ask away. Next up Im working on painting up some figures. Also more lighting around the diner to light the rest up. The idea is to run the track at night with only track lighting in the room. Also Ive already started working on the area behind the covered walkway near the phone box, which was grass, trees & a hedge. I also have a few cars Im working on to share soon. Also for those wondering, all cars on the track are slot cars & they all run. Im working on a small video showing the cars running around. Thanks for looking & another update very soon.
