Started this over the holidays. Adding to my growing list of unfinished projects.
So easy to get side tracked when digging through the parts box. Anyway, found
this JL Mustang body. Always liked the Mustang modifieds, so I started digging for
a roof.The donor roof is off a BMW which will have to be altered some to work.
Next step was to remove the front clip and interior from the body.
Next the body was narrowed to make it skinny and hug the chassis. I
suceeded in making it skinny, but maybe to much so, oops.
Pressed on and started making the mounts. Cut the mounts and set them to the chassis
and taped them on. Filed notches in the body so they would fit, test fitting the body
as I went. Once the fit was ok went ahead and glued them up. Once dry, tried taking the body
off. Thankfully it came off without a problem and all was well. Added a little bit more glue to fill
the gaps and set it aside to dry.
The roof mock up looks promising, it will have to be narrowed also to fit the body.
Once that's done, the hole filling and the rest of the body cuts can begin.
This one looks to be flowing along pretty good, hope it stays that way.
A little late but hope everyone had a good Christmas
and a Happy New Year.
All for now
Kevin
