NOTE: This is WITHOUT any surface texture. Not sure on exactly how the surface will be. If it's 100 grit sandpaper like NINCO or SCX, you can count me out.
From Maurizio: On the sides of the connectors you can see four passage zones where you can pass an additional wire to bring additional current cables underneath the entire track. Naturally we have studied the contacts in order to have a good connection, but the current is never enough, especially with the digital system.
I have seen some dimensions posted, but nothing I will publish until I know it is accurate.
