Aurora 32 Ford sedan hot rod
For 1/32nd Scale Models
Re: Aurora 32 Ford sedan hot rod
Postby VTECFOUR » Wed Apr 04, 2018 6:39 pm
Chassis assembled and running.
Powered by a Slot It slim can with a 3:1 gear ratio (10t SCX Pro pinion, 30t Plafit crown). Had to trim the crown's boss to fit. Motor mount is offset and the crown wasn't specified as such but the gear mesh seems fine.
Runs smooth but it won't keep up with Slot Its.
VTECFOUR
Postby VTECFOUR » Thu Apr 05, 2018 11:08 pm
Mounted the body with a single rear post with the front hinged from the axle.
Got the raked stance I was shooting for.
Tires are slightly rubbing so body and tire sanding should take care of that.
VTECFOUR
Postby Lou E » Fri Apr 06, 2018 4:02 am
That looks pretty cool, gotta love that raked look!
Lou E
Postby historiceng » Fri Apr 06, 2018 12:46 pm
I'm enjoying his thread, thank you Dan.
It look really good.
historiceng
Postby TuscoTodd » Sat Apr 07, 2018 4:48 am
That is turning out GREAT! Love the rake and hot rod look!
:handgestures-thumbup:
Postby VTECFOUR » Sat Apr 07, 2018 3:22 pm
Had these model truck wheels from a friend to make a mold. This "commercial" look could work so I cast them.
With a bit of filing and sanding for the fronts and rears, this came out.
I like the rears, not so sure about the fronts. Maybe with the axle coming through more will help the look.
VTECFOUR
Postby VTECFOUR » Sat Apr 07, 2018 5:41 pm
Considering this motor. Originally thought to be a Ford 427 SOHC but the spark plug positions in the valve covers are wrong.
Lots of room in the engine compartment.
VTECFOUR
Postby VTECFOUR » Sun Apr 08, 2018 1:19 am
Made some carb intake pipes from 3/32 aluminum tube. Drilled with a counter sunk bit to simulate a bell-shaped opening. Slipped on nicely and will position them more perpendicular on final assembly.
The motor's going to pop visually with some paint detail.
Working out well.
VTECFOUR
Postby Dundee Denny » Sun Apr 08, 2018 10:41 am
Sure appreciate all the details Dan!!!
Good stuff to learn from on this build!
Dundee Denny
Dundee Denny
Postby VTECFOUR » Tue Apr 10, 2018 4:58 pm
Got some gray paint on the wheel inserts.
Detailing the bolt heads in silver or gold will really make the wheels stand out.
Body's going to be painted a copper color with the motor in blue and silver.
VTECFOUR
Postby model murdering » Wed Apr 11, 2018 1:26 pm
Lots of progress!
Very cool Dan. Looking forward to the final scheme, but the meat and potatoes portion of the program is always the most intriguing part.
model murdering
Postby VTECFOUR » Thu Apr 12, 2018 11:43 am
Replaced the front axle with a longer one so now the ends protrude further out to replicate centre caps.
I like the look.
VTECFOUR
Postby Broman62 » Thu Apr 12, 2018 6:07 pm
Coming along nicely...like those inserts and that stance :auto-driving:
Postby dw5555 » Fri Apr 13, 2018 9:22 am
Reminds me of the Hot Wheels Demon I just sold.
Dave
dw5555
Postby VTECFOUR » Sun Apr 15, 2018 10:12 pm
That Hot Wheels looks like the "Lil Coffin" 32 sedan, definitely more radical than my effort.
Got some progress on modeling details.
Made some headlamp buckets from an airplane kit bomb and covered with a piece of .030" styrene hole punched. Positioned them low and attached with 1/16" brass tube through the rad cover.
Motor's paint detailed with a distributor made from 3/32" aluminum tube stuffed with wire stripped from a twist tie to resemble ignition wires.
Mocked it in place and the look is good.
Headers for the motor are next.
Turning out well.
VTECFOUR
Return to 1/32 Showcase
