Postby pfuetze » Tue Jul 10, 2018 11:45 pm
i was trying to be funny ... did not work out ... obviously ..... i meant a roll cage.
Postby pfuetze » Wed Jul 11, 2018 1:13 am
had to adjust the front axle, it had different wheel bases left and right. added spacers for the correct width in the front in the process.
tire trueing time! a "little" material sanded down ....
milled out the wheel to get more depth for wheel inserts, too.
tires came off the wheels even they were glued with CA.
did some scratching on the aluminium wheels, should be better now.
not bad for a start, something to work with ...
Mini is coming along ...
Postby BARC 1 » Mon Jul 16, 2018 12:30 pm
After A couple of months of not doing much with respect to slot cars, I decided I better get a Hill climbing car ready. I missed the Gaydon event and I didn't want to miss this too. It is a Heller Peugoet 405 rallye car with a brass inline chassis.
Re: What's on your bench right now? [1/43]
Postby pfuetze » Tue Jul 17, 2018 12:43 am
Hi Dan,
good to hear from you!
Very nice work on the 405, nice job enlarging the wheel arches, i remember this car originally being way higher ...
Postby BARC 1 » Wed Jul 18, 2018 10:49 pm
Don’t think this car fits within the rules. Will have to see what else I have to enter
Postby LloydL » Thu Jul 19, 2018 8:24 am
No problem Dan, there is plenty of time. If you cant get one sorted for class 1, class 2 is looking popular.
My hill is not big enough for a Pike's Peak type of event, but maybe someone will build one!
Regards, Lloyd.
LloydL
Postby taskak » Sat Jul 21, 2018 2:22 am
Great looking 405 Dan!
taskak
Postby walker » Wed Aug 01, 2018 1:21 pm
Do the two SCX cars have the original rims ? It looks like if they were printed ones.
Roland
walker
Postby pfuetze » Fri Aug 17, 2018 9:37 am
got an AGM Alfa Romeo 8c today!
the gear sound is really, really quite, nearly no play in the rear axle, front stub axles are okay. rotating guide with softer cables than on the minis i got.
paint is looking really good.
front lights work and look really good!
Postby BARC 1 » Fri Aug 17, 2018 10:14 am
That looks pretty good out of the box
Postby alexis in greece » Thu Aug 30, 2018 2:38 pm
OOPS
alexis in greece
Postby pfuetze » Thu Sep 06, 2018 1:58 am
a little progress on the Mini Sprint - finally the glass insert is considered ready for the lowered roof.
chassis is glued together, needs a little cleaning, but more or less ready for a first rollout. 2mm axles with ball bearings and cheap china gears m0,5
as my DSlot Aston came with a front wheel on the rear axle, i decided to swap the axles and wheels. Now it will get a 2.38mm axle with ball bearings and printed wheels. Made inserts from the orignial DSlot wheels, fit nicely in the printed wheels. need a little paint on prints, so.
Postby pfuetze » Tue Sep 11, 2018 7:56 am
added a hole for the diode (necessary for driving digital) to the GRC - chassis
GRC? Go! replacement chassis - a fully customizable chassis for go! components with magnet holder - magnet holder height adjustable!
Postby pfuetze » Wed Sep 12, 2018 12:23 am
Finished the printed rear wheels on the Aston. As written above, i got a car in the box with 3 front wheels and only one rear wheel.
So, i measured the original rear wheel and got a printed one from shapeways.
First, i tried to go with the flatened ends of the original DSlot axle, but this did not work out. totally out of round. So, i changed the axle to a standard 2.38mm axle, added ball bearings, got printed wheels again. turned down the original wheels to inserts to fit them into the printed wheels. painted the wheels with a mixture of black and silver to match the original color. i think it looks good now.
Postby taskak » Sat Nov 03, 2018 12:43 pm
taskak
