Revell Mono Vintage Nascar 67 Fairlane Chassis replacement
Postby JIMMYX3 » Fri Sep 28, 2018 10:56 am
We run a class of Vintage Grand National by Revell Mono. Is there anything out there that would be a replacment for the obsolete chassis for it? So far I found some of the Pioneer chassis are close but their not always in available, Wondering what would be a fit. :doh: any help would be welcome.
JIMMYX3
JIMMYX3
Re: Revell Mono Vintage Nascar 67 Fairlane Chassis replaceme
Postby Racie35 » Fri Sep 28, 2018 11:29 am
I think professor sells replacements for those.
Racie35
Postby Austin » Fri Sep 28, 2018 1:31 pm
Here are some 3d chassis out there.
Austin
Postby VTECFOUR » Fri Sep 28, 2018 4:08 pm
Consider building a metal chassis.
Mine's a simple ladder one with adjustable wheel base.
I like the modeling detail, so I kept most of the interior tray and driver figure
with a bit of cutting.
I just had the body, but I'll venture to say it runs better than the original.
It's one of my favorite builds.
VTECFOUR
Postby indidragracer » Sat Sep 29, 2018 7:32 am
indidragracer
Postby munter » Sat Sep 29, 2018 1:08 pm
I have a new (in bag) chassis kit if you need it.
Shipping will be $US10.00 because I am in New Zealand....plus the price of the chassis which is $15US.00
PM me if you want to know more.
Regards
John
munter
Postby Fathead59 » Sat Sep 29, 2018 2:17 pm
Nice looking chassis , I just hope the chassises I plan on building are any where close to the ones I see here , will be using the same concept with the frames I plan on building for my 1/24 scale dragsters I will build
Fathead59
Postby Fathead59 » Sat Sep 29, 2018 2:21 pm
I planning on using square tubing also , but the inside one will be square also, figured it would make the frame a little stiffer, and since they will be drag cars I figured the stiffer the better ( that what she wanted ) get that comment out of the way.
Fathead59
Postby Fathead59 » Sat Sep 29, 2018 2:26 pm
And they do sell the chassis for those models, I am using them for the RMS resin bodies I have, I had to add extra mounding spots for them , but that wasn't as hard as I would have thought. The only thing I had to do was sand down the mounting spots on the chassis so they would fit level with the body.
Fathead59
Postby Fathead59 » Sun Sep 30, 2018 5:31 pm
I know where you can get a replacement chassis if you are still looking for it, go to Professer Motor web site , part number is PMTR8508, it is the correct chassis for the Monogram bodies also because I got two bodies from SCC, and the mounting holes line up perfectly. I hope that helps, and I am sorry , I should have known what you were talking about before.
Fathead59
Postby Fathead59 » Sun Sep 30, 2018 5:38 pm
The only thing you may need to get is the bar magnets that go with that chassis, whose you will have to buy separate
Fathead59
Postby Fathead59 » Sun Sep 30, 2018 5:41 pm
And Munter , I wasn't trying to keep you from selling the ones you have.
Fathead59
Postby Fathead59 » Sun Sep 30, 2018 8:58 pm
Just another thing about the Monogram chassis, and the mag nets, Professor Motor has the magnets also , part #pmtr1032, you will have to cut them down a little but they are the ones that come the closet to size.
Fathead59
Postby JIMMYX3 » Mon Oct 01, 2018 6:57 am
Thanks Guys for all the replys
JIMMYX3
JIMMYX3
