After about five hours the print didn't look to impressive.
But I figured what the heck, so I got out the tools and started working on it.
First I mark the cuts, then dremel around the cuts, and finally remove the material.
After much sanding and adding some milliput it did show some promise so I printed up a chassis and a running mate for a build to start my own Ford Chevy wars.
Anyway The reason it took so long to scan was that I used the second download version. An issue that I created with the third download is that when scanning is after a scan you don't save it and move to a new scan. With the third version you stay in the same project and just keep scanning, moving the object between scans to get better coverage. I'll have to try another scan and write about that later but now I need to get started on the Mach 1 and Z28.
